- Replies 72
- Views 10.5k
Vinster_Beta 19 posts
LorenS 13 posts
Mopar1973Man 11 posts
dripley 7 posts
With my Pacbreak and @Dynamic valvebody. The Ebreak will lock in 2nd. Haven’t tried in 1st but I’m sure it will as well. The control module for the Ebreak has a wire you unplug for it to lock in 2nd i
If you do end up doing a manual swap I would recommend finding and nv5600 or g56 six speed transmission. I’ve got the nv4500 transmission which is great, don’t get me wrong, but the split in ratio bet
On a stock 47RE valve body, the 2-3 shift valve is hydraulically locked in the upshifted position when the converter is locked. That signal is removed in the modified valve body, which will allow a 3-
Currently I have a mostly stock 2001 Dodge 2500 with an auto tranny (sadly). It has stock injectors (probably original) and a rebuilt hy35 turbo and 5 inch straight pipe exhaust. No stud, no major mods. Have a quadzilla tuner and running a pretty mild tune off it and im trying to go for lower egts.
Eventually id like to make 350ish HP and thats about it. It tows regularly 3k to 14k constantly and and does pretty decent at it... Until egts start getting around 1200F.
Im trying to find a common Proven setup that works for this application. I do plan on putting an exhaust brake on it at some point and would like to try to steer away from having 2 turbo's and keep it simple.
Any suggestions?
