WT mod completed
47 minutes ago, Mopar1973Man said:
AC noise. What did you measure before at the alternator BATT post and after the W-T mod?
I didn't measure it before or after. I did the mod as its a sound easy thing to do. Got the fuse link for the PCM mod as well, installing it this weekend. going to use a 7.5a fuse for it.
Some of the mods that I have seen listed in the forums to me are a ounce of prevention to save a pound of cure later.
This ground mod is by far one of the best. Thanks @W-T
W-T:
Very mindful information to digest. I do understand the DVM's lack of precision! Luckily if I need one I have access to a Milliohm Meter and a MEGGER ohm meter. We use these in Aviation quite a bit actually doing bonding checks and resistance for grounds. Most of the electronics on an aircraft are highly susceptible to bad grounds, flight in rain, snow, high humidity ect... If I had a mind to go so far, I would actually do a VSWR alignment on the said cables to ensure the load and resistance are equal for each pair.
Now how is being annoying :D
I will eventually get to doing your above shown modification, however, I have alot of things that are must be done before I can work parallel battery cables.
As others have stated, Thank you for all your hard work and endeavors to help out the community!!
Stu, Wow! Voltage Standing Wave Ratios...indeed! :smart:
I find it so very contrasting in the mix of individuals who haunt this web site with exceptional backgrounds...it's so funny in generalities, where some people would think we're just a bunch of grease-monkeys playing with diesel pickup trucks. The sophistication one requires to be competent in this days automotive environment is pretty demanding and just assuming we are all a bunch of hicks makes me laugh.
Your experience and background in Aviation is an outstanding foundation...again it's so cool to have an affiliation with such individuals !
Annoying...not in the least...bring it on :cool:
Thanks
W-T
As W-T knows I have had two alternators go smokin hot on me. Saw the 150 amp fuse stud and nut holding the B+ cable to fuse holder glowing like a light bulb. First time was a shorted cell in the passenger side battery No 150mamp fuse and holder at that time. Second time with new batteries is when I saw the glowing fuse holder stud and hot alternator. The heat melted away the silver coating on the fuse end but, never blew the fuse. Both times my batteries were not correctly paralleled so the temp sensor could not tell the PCM to slow down charging.
W-T, you write so well good to read your write ups. :)
Stops the short circuit from burning up the PCM.  5A is quicker to shut down the short.  7.5A will still work but blows later.
Basically in a nutshell the blue wire on the alternator is a tach signal controlled +12V power source. When the alternator field is shorted out on the blue side it will pull the max current which is 20A till the circuit tracer inside the PCM burns up. Which my PCM did so well that it was declared junk because it burned not only the tracers but the fibergalss board too. With no way to repair. This is why I opted for 5A fuse so if the short occurs then the fuse blow out super quick and no damage comes to the PCM.
This is where the external regulator stems from because once the trace burns the alternator stops charging. So most installed external regulators. Now the problem is that all the external regulators from Mopar were temperature sensitive since 1962 or 1963 or so. As the under hood temperature would change the charging rate of the alternator would too. Common mistakes is trying the external regulator and either mounting it in a spot to hot (like near the turbo of exhaust) this will make it undercharge. Then I've seen a few mount in too cool of a place and now it overcharges and boils the batteries out.
So the whole PCM protection fuse is to prevent damage from short circuit on the blue wire.
NOTE: If the green wire was to short to ground it would charge at max rate. No damage comes to the PCM at all. Only the blue wire will do damage.
If I'm reading you right, if the fuse blows you just lost your alternator. Again, other than seeing battery voltage slowly drop off is there any other indication that the fuse has just blown? I have a ScanGauge so I will see a code and would eventually figure it out but will something jump out on the display (CEL, etc) that screams "Go check your alt and replace the fuse too"?
Yes. Secret. When the battery voltage goes from 12.00 to 11.99 the voltage will drop to 8 and chime the CHECK GAGES light. In my truck the cigarette light is gone and I installed a dual USB port with volt gauge. It also shows the actual running voltage. No codes will be thrown till the batter voltage drops to near 10 volts then a low charging volt code will be thrown. After 8 volts the engine will die. None of the computers will function below 8 volts.
I've got a 5A fuse on the blue wire. I've had the fuse work its way out and stop charging. Simply just squeezed the contacts slightly and re-install the fuse. Still in all the volt gauge will not be pointing at 14 any longer as soon as the fuse blows or in my case fell out.
I've also got a 150A circuit breaker on the charge wire to the passenger battery. I've NEVER had that circuit breaker trip once yet. I've physically press the trip button and again the battery voltage drops from 14 (13.5 to 14.5 normally) to about 12 volts and continues to decline till either the circuit breaker is rest or the problem located.
431k miles and still rolling. The W-T ground wire mod and my PCM protection fuse has been working flawless for the last 2 to 3 years with no real issues.
    "When the battery voltage goes from 12.00 to 11.99 the voltage will drop to 8 and chime the CHECK GAGES light"
   Good to know. I just replaced the alternator which was OEM at ~ 200k miles. It worked just fine so it's in my tool box as an emergency spare. Wonder how long a guy could go with the alt out. I would imagine if the lights aren't on, the radio isn't blasting and AC/blower off you could get pretty far before running out of juice.
   Anyway, thanks for the heads up.
Mostly depends on the condition of both batteries.
- John
I've seen a 1st Gen truck run over 8 hours with no other accessories running.
- John
Yup if the batteries are junk the time is going to be pretty short. If you got good strong batteries you could go for hours. Like Beast (2002 Dodge) I've got all LEDs lighting in the truck and reduced my electrical loads by a bunch. Each bulb is like barely 500mA.
Just a feel... Here is the front marker lights I'm using...
   Oh hell...I could go on for days then. I pulled the batteries from under the hood and have 4 group 31 Marine Batteries installed in the bed in front of the rear wheel wells. Also put a battery selector switch between the two sets of batteries so when we're camping I can use two for power (12 volt + 3000 watt Inverter) while saving the other two for starting only.
   Along with carrying a spare alternator, I can check that problem off my list of things to worry about.
