- Replies 38
- Views 5.8k
Mopar1973Man 10 posts
Alexio Auditore 6 posts
Silverwolf2691 6 posts
Dieselfuture 4 posts
Since my gear case is weeping behind the case and below the VP44. I pull the front cover off and tighten all the bolts I could reach and slowed the weep to near nothing. The only thing it cost was a t
If they where studs then yes. Head bolts will just stretch more. This why you have to measure the total bolt length to verify if they can be used again. Biggest thing is make sure to use t
I would use grey RTV to attempt to seal that.
Must be the year of head gaskets, because mines leaking as well, but im trying to hold off a little longer so I can be without the truck for a time.
But I'm not sure if I'm leaking from another spot in the front as well?
There is a plug that is underneath the thermostat housing that seems to be wet, even after driving a while. I know it's leaking above it, but that evaporates during the drive, while from the plug down, it doesn't. I can't tell if there is coolant leaking from the waterpump as well. I wipe it clean, start the truck, and I can see coolant coming up around between the pump and block, but that could be trapped coolant that is coming up between the two due to the engine vibration.
On top of this, I wiped the area down last night, and when I went for a drive and came home, checked again, and it seems like I have a oily film that was sitting of the housing of the water pump? Not much, but not green like coolant. Could I be getting some oil to come out from the head as well where it is leaking coolant? Is there a oil gallery there? (Passenger from)
No oil in coolant, no coolant in oil either (just did oil change sunday)
The gear case is wet with both oil and coolant below the water pump, and seems I'm leaking a little oil on from the gear case next to where the fan bolts to the block...
I went through some of the bolts on the gear case and found a least one that was very loose, so maybe that's contributes to some of my oil leaking issues
