ATTENTION ALL!
After I had a stent installed in my heart Nov 8th, 2023, I lost some muscle strength in my legs, which resulted in my left knee (7 surgeries) not liking the heavy aftermarket clutch in my 01 Sport HO 6 speed.
I traded it for a different diesel 4x4, but I just traded it for this 01 Ram 2500 Laramie SLT long bed 4x4 with 4-wheel disk brakes and 4-wheel ABS. It has an actual 195k miles on it from the vehicle record I paid for, which shows the same number of miles on the odometer.
It definitely hits a lot harder than the other 3 Cummins 4x4 trucks I've had before. It
It has the following upgrades.
1. FASS 165 lift pump
2. Borg-Warner 364sxe turbo
3. Aftermarket air filter
4. 4" exhaust
5. Edge Comp box tuner
6. Head studs
7. OEM Cummins head gasket
8. OEM Cummins valve seals
9. Power Stroke Products cylinder head
10. 5/16" push rods
11. Xtreme Diesel Perf P 108# valve springs
12. Xtreme Diesel Perf VP44
13. 150 hp injectors
14. New Starter
15. New built $4,400 auto trans 11/23 with paperwork
16. Crossover steering
17. Traction bars
18. Limited slip rear diff
19. New ball joints & wheel bearings
20. Aluminum radiator
21. MESA keyless entry with remote start
22. Custom LED tail lights
23. Mishimoto trans cooler
24. Kenwood deck with amp and all new speakers and subwoofer box under rear seat
25. 4" suspension lift
26. Rear air bags
27. Aftermarket exhaust manifold - haven't looked at it yet to see which one it is.
28. Glow Shift gauges for boost, fuel, trans temp, and EGT
At least now that I'm in a better 01 Cummins 4x4 quad cab long bed 4x4 (my favorite diesel), which came with a nicely built auto trans (with paper receipt from trans shop in Bend) and it has all the engine performance upgrades done to it. It will need minor repairs like a steering box due to too much play, and a power steering pump since it's noisy. It needs the following things to make it 100% again.
1. Instrument cluster LED bulbs
2. 190 deg thermostat because someone installed a 180 deg one
3. Heater treater fix (on order) and blend door actuator (already have)
4. Both front seat bottom foam and covers - typical Dodge seats
5. CB mount and high quality coax cable
6. Double din stereo with backup camera
7. Door decals and grille emblem - ordered
8. Replace the trans shift indicator PRND2L
9. Install new headlights with HID headlight bulbs - already have
10. Install under hood LED light kit - already have
11. Install Pos and Neg bus bars for better management of powering up accessories
12. Replace bad fuel tank sending unit - ordered it
13. Buy and winch bumper and winch
14. Install grid heater solenoids and cables to grid heater - previous owner deleted them
15. Fix minor engine oil pan leak
Edited by 01_Cummins_4x4
  • Replies 8
  • Views 1.3k
  • Looks like you made a good trade.    Good idea having the skateboard for emergency transportation while you are getting a feel for the truck's reliability.   - John
  • Mopar1973Man
    Nice truck. Very clean looking.
  • Doubletrouble
    Doubletrouble
    Nice truck!
- John
- John
Those were pics the respectful young man sent me of it. I tried the skateboard thing as a teenager, and always found small rocks to have it buck me off.
I drove down to Bend and back last Sunday for the trade.
That is a clean looking truck.
This truck is a factory Laramie SLT model via the build sheet on the VIN, but it didn't come with the overhead compass, outside temp, and mileage display, auto dimming rearview mirror, or power driver's seat.
Is the wiring already in place to add those items plug-n-play since it's a Laramie SLT model? I guess I will need to pull the overhead console down and see if the correct wiring harness is already there, or if I need to start grabbing parts from a pick-n-pull yard.
  • 4 months later...
I bought the overhead console harness, overhead console module, driver's side power seat base, and the wiring harness for the power seat. I added the required breaker for the power seat to the dash fuse panel. It was all plug-n-play.
Did This Forum Post Help You?
