who wants to rebuild thier VP44????
  • 1 year later...
  • 6 years later...
Hello,
I found this on eBay. It looks like a repair service where you send them your electronic unit and they will repair it and send it back. I believe there is no need for calibration. I sent them an email asking that same question. If it is true, then you can do the mechanical side yourself and outsource the electronic portion.
https://www.ebay.com/itm/REPAIR-SERVICE-VP44-VP30-Dodge-Cummins-fuel-injection-pump-EDU-ECU-module-98-02/132608417238?epid=1324680023&hash=item1ee013ddd6:g:YYgAAOSwtaRa6r7O
On 4/3/2019 at 1:31 PM, Yohan said:
Hello,
Definitely subbed
Looks fishi to me, plus I think them wires are stainless, not hundred percent. I don't think you can solder stainless. Looks like a used takeoff with clipped wires. Plus how is it getting calibrated. To top it off it's from overseas. Let me know how it works.
On 4/3/2019 at 12:31 PM, Yohan said:
Hello,
Ummm... So how to get your pump on the Bosch 815 test stand to be calibrated to the new PSG? I'd never run a VP44 pump with mismatched parts between the pump and the PSG. If it was so easy then the Bosch 815 test stand would not exist.
