straight pipe
My system with straight through 4inch "muffler" might as well have been straight pipe. The only problem was noise towing... sounded great running empty but that's not why I bought the truck! Yes tubos free spin after shut down... if you idle the truck & let it cool off before shut down, it should minimize the turbo spin after.
As everyone else has stated, that's one of the dumbest things I've heard in awhile! :)There's no back pressure, because there's no 'front pressure'.. :wink: It's just spinning.. It's spinning no more or less than before the straight pipe installation, it's just probably a lot more noticeable (read: audible) now that there's no muffler to 'muffle' the sound.That guy doesn't deserve to drive a 2011 Dodge. He needs a Yugo.
I am running a 5 inch turbo back pipe and have had no problems for several years. Yes the turbo spins down at shut down but not for much more than a few seconds. I always idle the engine until the EGT is below 300 before shutting the engine down. The turbo will be a LOT happier that way.
