- Replies 10
- Views 2.9k
Mopar1973Man 1 post
dorkweed 1 post
Wild and Free 1 post
angus 1 post
My front passenger side window no longer works. Nothing from both the passenger side switch or the drivers side master panel switch. That would lead me to believe it's the motor..........correct????? Or is this run thru the PCM also???I have no test equipment, so have do I check for where the problem is??? That window was always slower up and down than the others; even when new. In fact, on last years NoDak hunting trip, it was in and out...........sometimes it'd work, sometimes not.Thanks in advance!!
