Quadzilla
cummins
Ok so I just found out the company that makes my controller the quadzilla adrenaline its out of business now what? Well I been thinking that maybe I need to look into getting another one from a different company and the reason why I would like another one is because the one I have now I been having trouble with the buttons they wont work unless I press hard on them for a few times then they some what work. Any suggestions ? Also I would like to get a bigger turbo any recommendations I really get confuse on those things so please I would also appreciate your suggestions.Thanks!
You might could find a used Pulse monitor somewhere. . . You don't need to upgrade your turbo. If you get some bigger injectors you'll need to upgrade, but with +40HP injectors and the Quad, your HX35 is fine.
I tend to agree with Will... I'm using RV2575 injectors and my stock HX35W turbo and not having any issues with EGT's... Even towing...:whistle:
I had stiky buttons before on my pulse2 i took it appart and lined everything up, a lot better now than when it was shipped to me, seems to work good. are you saying qwadzilla is going out of buisness? them bastards :moon:
They went out of business in January.
I have a XZT+, and heard they were going away on CF, and somebody on that forum found almost all of the downloadable fuel maps and put them up on a site for free. I have most of them now. I'm just going to keep the Quad till it doesn't work. Then I'll get something else. I'm happy with the XZT+, only has 3 position toggle not much to wrong.
Thanks everybody, I think I will stay then with the original turbo and am going to try to open up the controller to see what can i do about the buttons if not I will try and find a good used one some were. So if my EGTs are running at 750 to 850 on 4th gear is it ok there because if I step it up to 5th gear then my EGTs jump to 980 to 1010 of course all this is pulling the trailer.
If those are pre-turbo temps, then you're safe.
