Just upgraded to hx35, not happy
- Replies 55
- Views 23.8k
Mopar1973Man 6 posts
AH64ID 5 posts
Rogan 5 posts
Col_Psoas 5 posts
So here's the deal. Truck is an 02 with a built auto, 120k miles and edge comp with tapped wire, stock injectors. After tons and tons of reading I decided that upgrading to an hx35 would be better for the truck and just make the truck better overall but I honestly don't know how to feel about it now that I'm doneThe truck makes way more heat on the egt's. Like everywhere but way up high in the rpm range. With the stock injectors and pinned I can only just barely touch 1250 unloaded but this was impossible with my hy. and whereas my hy made a max boost of maybe 20 the hx makes about 37 max psi.whats going on here? I get more heat, less spool up down low. Higher cruising egt's and lower crusing boost pressure just running unloaded down the highway and the only improvement I can see is when I'm pushing it hard but even that is next to nothing (more air but doesn't feel any different, same max temp), certainly not worth the cost.Any thoughts here guys, should I just put the hy back on and be done with it? Currently I'm not hauling or towing so its just unloaded highway driving but it feel less responsive but with similar mileage and higher cruising temps? No boost leaks anywherethanks for your help guys
