- Replies 13
- Views 2.2k
bry1216 3 posts
Mopar1973Man 2 posts
oldbeek 2 posts
ISX 1 post
Truck is at operating temperature, although what I describe below happens while starting at cold temp. I installed the FRRP-100 last weekend and set the pressure to 19.0-19.5psi at idle. Notice the normal initial 2 sec run at ~21.5 psi. After starting, it runs at ~15.5 psi for 15 sec and then jumps to 16 psi - finally it jumps to 19 psi and the engine sound different. Coincidently the ScanGauge 2 comes on at the same time. Is this a function of Open vs. Closed loop of the VP44? Is this a function of the ECM? Thank you.
