Better way to bleed fuel system??
- Replies 19
- Views 32.7k
Texas CTD 5 posts
GreenRiverCummins 5 posts
Mopar1973Man 2 posts
bjytech 1 post
So took the time today to change the oil and oil filter and fuel filter in the work truck. oil went of easy as alway's but the fuel... "shiver" Well It's a 1998 24 valve did the same routine as i have for year's 1. lossend the nut on the filter housing2. drained the old fluid from the housing3. replaced all the gasket's (3) and replaced new filter4. Filled up canister with fresh fuel5. turned key on 3 time's to then bumped key twice to ensure complete primie 6. turned the motor over fired right up for about 5 sec's then stalled and died..So after trying to bleed the line's at the valve cover for 2 hour's started at #1, then 3, 5, 2, 4 only # 4 bubbled a little after the motor was shut off. That's it what am i doing wrong using a lite mist of starting fluid to get the truck to start then die's a few sec's later. What am i doing wrong driving me crazy 3 hour's of bleeding still nothing.
