Hey Gang...
We got a new feature here I gotta set up. It's a Acronym feature. In other works we can continue to use acronyms in our post but like if I was talking about IAT sensor you notice the "iat" is underlined and if you hover over it it shows the acronyms actual meaning. So time to gather up the acronyms and get them posted here.
Posted (edited)
KISS. Keep it simple stupid PFM. Pure fing magic Ok serious time Ckp. Crankshaft position sensor Cmp camshaft position sensor Kdp. Killer dowel pin Bhaf. Big honking air filter
Edited by mopartechnician
Posted (edited)
FCA-fuel control actuator
WIF- water in fuel
HPCR- High pressure common rail
IP- Injection pump
PTO- Power take off
HOAT-hybrid organic additive technology
IOD- Ignition off draw
PDC- Power distribution center
FICM- Front integrated control module
IGN- Ignition
CV- Constant velocity
NV4500
NV5600
G56
47rh
47re
48re
68re
VE
p7100
Vp44
CP3
Mopar Icon Notes
For the acronym feature to work all letter MUST be capitalized for it to show up. So if you have lower-cased letters mixed in or all lower-cased then the feature is disabled.
Also lets get these all gather up as much as possible and I recount/repost the these so they all show up.
Posted (edited)
MPG Miles per gallon
TDR Turbo Diesel Register
CF cummins forum
EGT's <--with the 's, dunno if that works still?
MPH miles per hour
PSI pounds per square inch
OD overdrive
...well look at that, some of them are already in!
Edited by hex0rz
Posted (edited)
HAHA!
CRS... Yep, I know that one.
UOA used oil analysis
LMAO laughin my arse off
IIRC if i remember correctly
IMO in my opinion
IMHO in my humble opinion
FWIW for what its worth
Edited by hex0rz
Posted (edited)
Cat uses this SOS = scheduled oil sampling
I have not seen these yet either :tongue:
B!H = big ! hammer
WT! = What the !
! = F
Edited by Wild and Free
