I should be hopping on the dyno this weekend (As long as my brother doesn't blow up his 05 first)
Couple of questions: Anyone have any thoughts on which level for a smarty only run? Any thoughts on which level for a smarty + TST run?
And for the fun part! Guessing
Give your guess for: Smarty only and smarty + TST   My sig is up to date!
Am definitely interested in what you put down, I'm buying a new turbo this spring and am 95% sure I will be buying a phatshaft.
I've never ran my Smarty stacked, but being your goin for broke I'd think 9 on the solo run and 8 stacked. Then max out TM, injection timing on 3-4 and duration 4.
Will be "watching" from Ohio!
Did ya  get the  miss fixed?
TST does not do timing so I will be running odd numbers at all times on the smarty!
325 with everything turned up. Not much difference without the smarty and 275 with only smarty. I was ever happy after I got off a dyno and every dyno was different.
Think that low with the injectors and turbo?? I know I'm at altitude but I can blow away tuned CRs
Nope.... Figured what the heck if it's something bad enough it'll fly apart on the dyno and I'll know the problem :lol:
You going to to see a cut off where the Smarty drops dead at. The low end will look really good but after 20-25 PSI of boost the numbers will flatten out. Because at that point the fuel table ran out and your running solely on injectors.
It'll be nice to see where the smarty falls flat on it's face. I was thinking leaving the smarty alone between smarty only and smarty TST runs just to see the difference in graphs. Although you'd be surprised... I pull hard up to 37 psi on the smarty only.
Sounds like you guys want me to break it!! :lol: Only thing I'm scared of breaking is the input shaft to my trans.
My brother's 05 well it has a bit more done: 62/65/14 over s475/96/1.32 Exergy 100hp injectors, Industrial 85% over cp3, arp 425s, 03 intercooler (Blew op the stocker), SB DD clutch, nv5600 trans, 110lb valve springs, UDC tuned by me.... It should lay down some pretty nice numbers! You guys have any guesses for it??
The only thing that going to happen is get up on the roller. They tie you down. Then the controller will tell you what to do. Typically you get into your highest gear and hold for a second controller will tell you to drop the hammer. You'll run up to near 3k on the tach then let off. I've been to several dyno events with a local Idaho group.
Intercooler boots are the most common thing I have seen blow on the dyno. make sure the clamps are tight before doing it. The other failures come from guys running too much Water meth or nitrous.
At the big dyno events the Dyno owner /  operator runs all rigs on the dyno to get a better more accurate run from all rigs, he will ask for the basics from you and then make a few feel runs to see where the tranny wants to kick down at ect.
I won't run it in 5th. 4th gear only for me.  I believe we can drive if we want... I mean it's a manual so it can't be too hard! Drop the hammer when they say go!  Wild this one is next door to ATS. 10 days is the ATS dyno event.
4th will give you similar hp, but less torque than 5th. I saw a 50 ft/lb drop in tq doing my runs in direct instead of OD, as the turbo doesn't have time to light at the lower rpms in direct.
How you load the engine prior to the green light is how good your torque will come off. Personally I get to 1400-1500 rpms and start aplying brake and throttle to get the load/boost up and then let her rip. The total and mid range power is very different than just dropping the hammer.
Take a few seconds each run while you prep to ensure the motor it up to operating temp as well.
This is totally dependent on if it is a load cell dyno that puts a load on things for you which if calibrated is the best and most accurate, or an inertia dyno, the most common but less accurate in this case then John's advice is best.
curious   Since   HP  is just  a  dumb  mathematical number  derived  from   torque vs  speed.    And  torque   should be measured  by  how a shaft  responds  to  increasing loads...
Does  anyone  KNOW   whats  going  on   with   the    drum   when the  green light  goes off?   Is it  a  simple    constant load,  or is it  being   increased or  varied    as  drum  rpm  goes up as well?
I've  measured a lot of   engines  with   the    pto  method.    Run the engine  up to  rated speed,  and   start  increasing the load  to a certain  rpm drop.     The   'difference'  is  then  calculated  to  a  torque  measurement,  and    from that     HP  is  easily  calculated.
Granted,  this  way is   for   true 'rated'  HP,   one  where  the  engine could  withstand this load  continuously,   day after day.
Point I'm  trying to ask is;   unless  the     load  increases, (which  on a  could be programmed to  change several times a second)  and  engine performance  is  instantly measured      Nothing  really can't be compared  and  then   calculated!    a  simple  spin up   from  zero to  100mph   means nothing    on  a     static load...  unless it's  timed.
All I've ever seen is  a  quick spin up... and  a bunch of   guys  huddled around  a  computer  screen  and  giving  high 5's...
