So for all you guys using a 21/64, were these bits you had before hand or did you get specifically with your EGT kit?
I'm asking because I purchased my gauges from Vulcan and ordered the drill and tap as well since I didn't have any. I noticed that my drill bit says 11/32's. Is that going to work? I saw this CHART and it obviously there's a small difference in size. Will that matter at all?
It's one of those things where, yea it's only 1/64th but does that make or break it. I figured that Eric wouldn't of sent me the bit unless it was the right one, unless it was just a mistake. I'd rather not take off to much and have to tap the hole to far. I may just swing by and get a 21/64th, I have a 1/8th tap so I should be good to get there.
I think it would make the tap job a bit easier when using the 11/32. I do believe that the 21/64 is a reamer size. Meaning that the npt style thread is tapered and the reamer will angle the hole to make the tap fit perfectly. Not entirely necessary for this job.
  • 3 months later...
