- Replies 27
- Views 6.9k
Turns out there was a broken chord in the drivers rear. The put the spare (5th tire of the same on) and away I went with a smooth driving truck. A set of 4 new Cooper S/T Maxx will go on tomorrow
The new tires are on and the truck is very smooth and quiet. I had couteract balance beads put in, same as my 19.5's, and the tires don't feel like an aggressive tread at all up to 75. The ne
Yes they are. There are currently only 2 tires made in LT255/80R17. These S/T Maxx's and the BFG KM2's I just took off.
I am pretty sure I know what it is but wanted to get y'all's opinion as well.
I drove from outside Challis to Kuna, ID yesterday. The first 55 miles was dirt and then the next 170 miles of pavement everything was smooth as butter. Speeds up to 80+ at short times but cruising (if you can call it that on mountain roads) at 55-70 for a lot of it. Came to a stop at the intersection of 17/55 and got onto 55 and noticed a bouncing that was the worst at 35-40 mph. It smoothed out a little by 55-60 but I didn't push it past 60.
There is no vibration below 30-35 and rpms have no effect (i.e. lug in a tall gear or 3K in a lower gear).
I am thinking a tire might be delaminating but unsure. It is definitely on the rear axle area as I feel it more in my seat than my feet and nothing thru the steering wheel. The transfer case lever is moving laterally up to 1/2" at 35-40 mph. My 6yo was in the back seat and said she felt it behind her without prompting. I told her I thought we might have a bad tire and she said, yup its the back ones I can feel it bouncing.
Pressures were good, tires weren't hot, but the drivers side rear is wearing a little funny. They are my KM2's and the soft lugs makes the outside lugs wear faster from cornering (not a BJ issue as my M608z's wear dead even). Now I noticed that there is contact on the tire between the lugs (they are nearly worn out anyhow).
So.. thoughts?
I am going to go have them checked today on a balance machine.
