Grinding sound when driving straight or turning left
- Replies 17
- Views 5.6k
Ironforger 3 posts
Hawkez 3 posts
Mopar1973Man 2 posts
Me78569 2 posts
02 3500 QC6 speed RWD 215k
Independent front suspension.
When driving straight or turning left, there is some kind of low mechanical grinding sound coming from the right side of my truck. With it is a slight vibration. Hard to tell if it's from the front or rear of truck. The sound disappears when making right turns. The tone changes with speed increase or decrease, and its most noticeable between 40mph and 60mph so it's definitely something rotational. No difference if truck is in gear or coasting in neutral. Issue has been gradually getting worse over the past few months.
I suspect front right wheel bearing but would like to hear some opinions here.
Front wheel bearings are all original equipment.
Rear wheel bearings are new 2 years ago (approx 6000 miles) - top of the line timkens
Steering tie rods and idler arms all new. Balljoints all original equipment - one is slightly worn. All ball joints to be replaced in near future.
Brakes are good - recent new pads, calipers etc.
I jacked up front of truck - inspected wheels - no noticeable play and wheels spin freely by hand no noticeable noise (sans slight brake pad drag)
Thanks
