inexpensive borescope
so i have this app called "geek" and it has mostly chinese stuff but a lot of it is good quality nicnac stuff.. i did find a borescope for about $8 that plugs into usb and works like a champ lights and all. then i searched for a 5.5mm borescope and they have them (size we need to get into the cylinder through injector hole).
So i figured id let the community know of where to get a fairly good working borescope for engine inspection for cheap!!!
i w et agead and purchased the one in the pic and will do a write up on it.
Mike if its possible to make this a global post so everyone sees it and can use the info please do!
Edited by CUMMINSDIESELPWR
  • Replies 31
  • Views 6.9k
  • Mark Richart
    Mark Richart
    http://www.amazon.com/Diameter-Waterproof-Endoscope-Borescope-Inspection/dp/B00N4L5N4A/ref=pd_sim_328_5?ie=UTF8&dpID=51GhC8fSwCL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1HTR0PNY
  • CUMMINSDIESELPWR
    CUMMINSDIESELPWR
    nice!   here is a snapshot from my pc looking at its own motherboard about 2" away with the borescope i got
its not a page, its an app you download on the phone and purchase through, ive bought a lot through it so i can vouch for it.
nice!
Interesting app, thanks for the share.
5 hours ago, The_Hammer said:
That's the one from the Amazon link above?
no its from the geek app on my phone
i havent bought from amazon
I wouldn't mind something like this to run down a rifle.  Thanks for the link.
30 minutes ago, JOHNFAK said:
Mine was useless down the cylinder
Why is that? Seems like it'd be good for determining TDC for each cylinder during valve seal replacement with head left on.
Dang it, I was getting a little excited about this.  Have it strapped to somewhere on the truck, and watch what's happening from in the cab!  My first thoughts were wastegate.
So is there an adapter that plugs in to phone or do you got to have laptop with you.
5 hours ago, CUMMINSDIESELPWR said:
these caneras have leds on them and they are usb so a tablet or laptop is needed
You can get a micro USB and that will work directly with your phone.
Then software app called CAMERAFI.
Screen for phone then becomes your screen.
Cursious to see some injector/cylinder pivcs from your setup - maybe its better (hope so).
From what I've found on this camera it is only does VGA (640x480) and does NOT do 1.3mp or 720P like it claims where there getting the claim of it being a HD camera I don't know.
everyone slaps HD on stuff these days and i knew for the price it wasnt gonna be hd, however it does pretty good for our need of something that is used infrequently and usually costs hundreds for the high end stuff.
