inexpensive borescope
- Replies 31
- Views 7.7k
CUMMINSDIESELPWR 10 posts
JOHNFAK 6 posts
Mopar1973Man 3 posts
gh0stman 2 posts
http://www.amazon.com/Diameter-Waterproof-Endoscope-Borescope-Inspection/dp/B00N4L5N4A/ref=pd_sim_328_5?ie=UTF8&dpID=51GhC8fSwCL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1HTR0PNY
nice! here is a snapshot from my pc looking at its own motherboard about 2" away with the borescope i got
so i have this app called "geek" and it has mostly chinese stuff but a lot of it is good quality nicnac stuff.. i did find a borescope for about $8 that plugs into usb and works like a champ lights and all. then i searched for a 5.5mm borescope and they have them (size we need to get into the cylinder through injector hole).
So i figured id let the community know of where to get a fairly good working borescope for engine inspection for cheap!!!
i w et agead and purchased the one in the pic and will do a write up on it.
Mike if its possible to make this a global post so everyone sees it and can use the info please do!
Edited by CUMMINSDIESELPWR
