Improve Safety?: Front End/Steering/Lighting
- Replies 24
- Views 5.5k
jamman 5 posts
Mopar1973Man 4 posts
CSM 3 posts
Me78569 3 posts
You already have the HD setup on your truck. I think your truck is just stock height. My blocks in the rear are the same height.
as for lighting. http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/31-exterior/504-retrofitting-bi-xenon-projectors-into-your
If you clean it up good and seal with paint is better than leaving exposed and rusting. I'm also northern truck but to this day I've kept the rust at bay for 13 years heading for 14 years. Powe
Situation: Beginning a new job soon with 145 mile daily commute on hilly, curvy roads. Limited snow and ice. Truck still has play in steering, poor OEM lights, and mileage is sadly around 12mpg the last time I calculated it. Steering was some improved after addition of Luke's Link, but at highway speeds of 70mph the truck required me to keep 2 hands on the wheel to make sure I had control at all times.
Truck: ’99 Quad Cab w/8 ft bed. Installed lower(?) balls joints on both sides a couple years ago, er...had installed. Installed Luke’s Link on OEM track bar Aug 2015 as I put on new tires and it could be aligned due to slop in the front end.
Goal: 1st is safety. That means I have to see when I’m in the dark. It also means that I have to be able to keep the truck on the road with all the curves. I want to do what I can, within reason, beyond just keeping the foot off the pedal to improve the fuel economy (I know I’m not going to get huge increases, but even 2-3mpg would be great).
Plan of Action: 1st, I’m going to crawl under the truck and make sure the Luke’s Link is still tight and see if any other components are loose. I’m no front suspension expert, so any pointers or directing me to specific threads would be great. There is almost TOO much info to sift through sometimes.
2nd, I have spoken with Daniel Stern about lighting. I’m going to install a 12ga harness for the lights to give them the full amperage they deserve. I’m also going to replace the OEM bulbs with Phillips improved 9004’s. When I get the money, I will then replace the OEM light housing with the OEM Sport Housing. Daniel convinced me to stick with the engineered components for longevity and reliability. I’m toying with the idea of adding some of further lighting like Mike did, but only after I have everything up and running the way it ought to be. Btw, my stock lights are about as hazed as can be. I know it isn’t great, but may try and sand them for a temporary minor improvement while I wait to get the money to order my sport housings.
Question: What more do I need to do to get safe for all the hills and curves right now? Am I needing to replace track bar with HD version and that will improve steering/handling? I know I need a fuel pump ASAP and gauges, but those aren’t safety issues. I need them soon, as this truck has over 150k on the original VP44. But the front end and steering are what really has me a bit concerned. I know we all have lots of irons in the fire, but with everyone’s experience I hoped to save some time by at least having you point me to “go that way” rather than learning all aspects of the front end on a short time frame.
Thanks for the help!!
