Looking for Staff Members
  • Popular Post
Well new to me at least!
Some of you helped me out in my other thread when looking for one. Well I finally pulled the trigger and picked one up!
It's a 2002 4x4 QC LB auto. Single owner, garage kept majority of its life, never had a goose neck or 5th wheel (which is harder to find than you'd think up here). Came with a 2in leveling kit and 35's and a hypertech 'tuner' to fix the speedo. Other then that, she's all stock. I crawled under to check for any signs of a 53 and couldn't find anything, so I might have a mexican block, but I'm going to keep checking. I couldn't be happier! I originally wanted a manual, but the wife said, if I'm getting a new truck then she better at least be able to drive it. So rather then argue, I just said 'ok' and got lookin!
Anyways, wanted to start a thread here because, since it is stock and I'm planning on keeping this truck for the long haul, I wanted to do some mini write ups of the mods and what not I get done to her. As of now, here's the order I want to go in:
1. FUEL! and lots of it!
2. Gauges
3. Steering
4. Transmission
5. More power!
3 and 4 may get swapped around depending on what's needed more and my budget but that's the general order.
So to start, fuel... The stock injection pump was replaced by the dealer 50-60k miles ago so it should have some decent life left, and it looks like they moved the stock lift pump. I didn't track it down exactly, just looking fairly quickly, and couldn't find it mounted on the frame, did they do in tank LP's for 02's? I'd like to fatten up my fuel lines to 3/8s everywhere possible, also looking to go with the Fuel Boss, but not sure how that works if my LP is mounted in the back in tank if that's even a thing. Any ideas or experience with this? As of now I'm looking at getting the following for step 1.
FUEL BOSS ----- BIG LINE KIT ----- MOD FUEL MODULE
As far as fuel lines, the obvious is the big line kit from Vulcan but I figured I'd talk with Eric about getting lines replace as much stock line as possible. I also threw on the modified fuel module. I saw that as I was browsing their site and hadn't seen it before. Is that necessary at all? Keep in mind I'm just looking to have fuel flow as easily as possible through the truck. When more power rolls around I don't plan on going EXTREME, but would like lack of fuel to never be thought of again after this.
I'll leave at this for now but really looking forward to wrenching on this truck and getting her setup for the long haul!
  • Replies 238
  • Views 31.1k
  • Quick update post here... I had to get mud flaps put on the truck  I'm personally not a big fan of flaps or flares but local law enforcement sure is!  Anyways I had a local shop fab up some brack
  • Ok so just wanted to put this here so I can have everything I've done on the truck in one spot.    I wanted to copied Mikes idea of putting lights up under the axle because I couldn't see an
  • SWEEEET!!! As for fuel, it's located on the block from the factory. Since the IP was replaced by the dealer you now likely have the in-tank pump. I'm not familiar with the mechanical pumps,
as long as you are sure that it is just dented and not punctured.
That's the pump I'm going with next after my Air Dog goes bad. I'll get it without the filters since I have a Racor pre filter.
Looks like there are very few problems with Fass and that's good
On ‎3‎/‎1‎/‎2016 at 7:08 PM, notlimah said:
image.jpeg.5f554ef3d376a45eedb0eca24a7f2
It wasn't a huge problem, and my fault but set me back enough that I killed all my remekning daylight. So tomorrow I'm hoping to get the FASS wiring and tubing done tomorrow and should make good headway on the gauge install as well. I'm not planning on teeing into the stock fuel filter and I don't need to cut the filler tube so I'm hoping that saves some time.
Anyways, more to come!
There is a way to make your own terminals that are much stronger. You can make them out of copper tubing yourself if you have a bench vise.
Thanks guys. I'm 99% sure it's not punctured so I'll double check one more time before giving it the go ahead. I'll have more pics of the whole install later.
@JAG1 No bench vise but I'd like to see how that was done!
5 minutes ago, Me78569 said:
for what it is worth, My pureflow pump is doing great.  Hasn't missed a beat since it was installed 2 years ago.
I think the model number is FP-125 from http://www.pureflowtechnologies.com/
Thanks Nick.... my AD100  has been flawless for about 5 years now. Notice some weakness when hauling heavy running up hill. I think they have gotten over the problem with fuel getting into the electric motor.
To clearify,
pureflow does not = airdog, two different companies, airdog pays for the right to build pureflow pumps for light duty trucks.
After talking with the pureflow owner, the license holder for the airdog,  he told me that airdog changed the design without getting approval from pureflow.  That is where the issues came from, pureflow required them to go to the 4g series pump, which is a pureflow design.   Once the 4g pumps got out there a lot of the issues went away, but there are still a TON of faulty pumps floating around here and there.
Still cheeses me off that airdog never gave a "hey we're sorry we screwed a bunch of you over" speech.  but oh well, I don't have to worry about being left on the side of the road anymore thanks to pureflow.  They were beyond awesome to work with throughout the issue.
Edited by Me78569
6 minutes ago, Me78569 said:
To clearify,
1
I've also had the same conversation with the owner of Pureflow.
If I go to replace my 10 year old Airdog 150 I would most likely spend the money with Eric @ Vulcan Performance for a second AirDog 150.
Somehow I got the impression they were the same company called Pureflow and that 'AirDog' was the name of the pump. Thanks for the clarification.
How would you make sure that you did not get one with the flawed design? I guess Eric would know :thumb1:
I don't think anyone knows honestly.  Airdog either does know when group of serial numbers has the issues or they are unwilling to release the numbers to us.
I THINK, take that with a grain of salt, that any 4G pump should not suffer from that issue.
If it weren't for the skepticism over the Airdog systems, I would've done the same. I'd go out of my way to support guys like Eric in our industry but to me there wasn't enough certainty in that system to justify going with them.
On 2/29/2016 at 8:16 AM, Mopar1973Man said:
Silly quote tree I cant figure out how to delete
I had an early model airdog and it ran fine, but I like the additional heft of the fass.
 I like eric, no doubt, but I hate the way airdog has treated their customers with their craptastic run of bad pumps.
I have never had a problem with the mounting location of my fass either in front of the tire... Colder, mabe, but no problems so far.  It also is high enough to be clear of the body and well above the frame rails.
Edited by CSM
Yea I did a mock up mount last night to get a visual of how things would look and I think it'll clear everything and it'd be out of the way of the tire spray. Hoping to get the FASS and gauges installed today and finally be able to drive the truck again!
I put the ADII 165 on mine about 6 years ago. About 8 months ago it started popping fuses. AD sent me a new one with few questions asked and it has run fine since. If I read the sticker on it right it had a build date of late 2014. Just still have that nagging thought about them in my head.
Alright well I made some headway tonight but started a lot later then planned so I lost day light pretty quick and the weather wasn't the greatest. Needless to say I don't have pics for now.
But the pump lines are layed out in the truck how I like them, just need zip ties. FASS is mounted and looks pretty good I think. All that's left is to put the new jic fittings into the VP. Then it's on to gauges.
I'm thinking of running this setup for my fuel pressure gauge. This is how I want to tap into the fuel line.
image.jpeg.95bce706e8cd5696e34eac7f618ae
Whatduya guys think? Will it work? My idea behind this is to mount the needle valve in a more conviniant spot. Since I'm not using the stock fuel filter housing I figured I'd try mounting somewhere that works better for me in case I have an emergency shut off situation.
Pics coming soon and more to come!
14 minutes ago, Mopar1973Man said:
I would of mounted the needle valve right at the tap point. Now when that hose failed your going to be stuck with ZERO way to shut down the fuel.
But how often does hose fail?  there is a lot of hose in his fuel system before it gets to that tee.
Both valid points for sure. If the hose failed I think I'd be getting a tow regardless. I'm more concerned about being able to shut down fuel leaking into the cab quickly if that were to happen.
