Brake shudder at higher speeds
- Replies 19
- Views 5.4k
Mopar1973Man 4 posts
KATOOM 3 posts
lcattin 3 posts
Nekkedbob 2 posts
I was a field service tech and drove my own vehicles and they usually made at least 300k before I sold them. I found that using the cheapest pads would not ruin the rotors and since I did this I only
I found this article interesting about warped brake rotors. http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
Agree'd I run the cheapest of the cheap when it comes to pads. I would rather have the $5 pads wear than the $100 rotor.
I hope someone can shed some light on this issue for me.
On my 99 3500 2wd last year I put all new brake hardware on the truck. Rotor/hubs, calipers, pads and this weekend had to put a new drum, wheel cylinder and shoes on one side in the rear.
What happens is that just recently the truck started shaking, bouncing when applying brakes from a speed above 50 or so.
Yesterday I pulled the front wheels and checked the rotor runout and the passenger side is only about .001" but the driver side is right at .007" runout on the face. Also looks like some hot spots on both rotors also. I put high end pads on the truck. Will the cheaper pads run cooler?
Is that enough to cause the problem that I am seeing? I can feel it in the steering slightly also.
