First, my question.  I have her all torn down to the point where I just have to remove the timing cover.  Fingers crossed no grooves on crank.  222K on the clock.
I bought a cummins seal at the dealer.  Says cummins on the part.
Question..... which way is OUT?
Logic tells me this side should face INWARD towards the crank:
And this side OUTWARD facing away from the crank:
Reasoning, the second picture has a rotational marker.  when facing you it is clockwise.  when facing the front of the truck, the crank turns clockwise.
Why am I asking?  bc the plastic alignment piece is conical (cone shaped).  you have to pull tight from the front and it will actually expand the inside of the seal out a good bit.  i assume this is so the seal will fit over the crank shaft nose.
You would literally have to pull this cone through the seal by pulling it up through the seal in this photo correct?
btw, I am doing this via the dodge service manual which says install in the cover first.  i have no depth tool so i am going to have to wing it and hope.
this is what the dealer did to me...... twice.  he put it in the wrong way and not only did he do that he put on gray silicone rtv on both the inside and outside of the seal.  no no no no no!
right hand side of the photo also broke the lip the seal goes into. before i took this apart he told me to buy a new cover b/c he thinks it was warped.  ummmm.... or u broke it.
This one you can see how this is really installed backwards:
moparman you may know this thread from another forum.  i got banned b/c i was upset and cursed with stars to filter the words.  no warning no nothing.  just banned.  still need help though.  this has been going on for 4 months.
Edited by bms231
  • Replies 84
  • Views 19.8k
  • Wild and Free
    Wild and Free
    This is a perfect example of why paying with a CC in certain instances would have gotten your money back on a contested service as you have all the evidence against the dealer on a screw up and then s
  • If everyone did it themselves wouldn't that put you out of a job?   I'd much rather do my own work as well, but I don't have the skills that most on this site posses.  But I always look forw
  • my article is complete..........   https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/12-and-24-valve-front-crank-seal-replacement-r474/
I got banned from a forum too because I was mad about a new $23,000 camper with so many problems. You would not believe how many people joined the 'click' to talk bad about me and I was the one who got the bill of goods to fix everything.
I don't think you can be banned around here we just fully understand and with limitless effort try and solve the issue.
Welcome to the forum and I know you will get an answer soon here boss.
Your correct on the seal placement. Just that I typically remove the cover and drive the seal in. Now take notice to the position of any old grooves. I'm sure there is. The plastic sleeve is to get the seal started over the crank once the cover is in place you pull the plastic sleeve out.
Edit I didn't realize till now that seal is in backwards. :thud: No wonder it leaks.
yup. he did every possible thing wrong.
I saw the other thread on here about the seal. my only issue is everyone seems to use a different seal with sleeve. I will probably have to once I see the crank tmrw.
we all agree... seal installed in cover first?
I read somewhere depth doesn't matter as long as ur not in an existing groove.
Edited by bms231
It gets better.  not only did he damage the timing cover...
he marred the surface of the crank.  i don't know where to go from here.  I am stuck.
This one is the most upsetting.  I can't even get a seal on here w/o sharp metal cutting it.  I assume I have to file this down, but it still leaves big pits.
I seriously have no clue where to go from here.
I see this:
http://puredieselpower.com/dodge-products/03-07-dodge-5.9l-cummins-front-crank-seal-with-speedy-sleeve.html
I was honestly thinking of using this autozone sleeve.  use a little bearing mount to mount it to the crank.  then use the stock cummins seal over it.
http://www.autozone.com/internal-engine/crankshaft-seal/duralast-crankshaft-seal/dodge/ram-2500-3-4-ton-2wd/2001/6-cylinders-7-5-9l-turbo-diesel/630211_726041_4222/?checkfit=true
I saw this on another thread.... is this thing even seated far enough back?  Does the seal run along the backside lip or anywhere on the "repaired" sleeve portion.  I assume the later.
The first thing I would do is have a heated conversation with the caveman that did that work.
You'll have to get the seal/sleeve kit. I don't think a stock sized seal is meant to fit over a repair sleeve.
it's kinda like which kit though.  cummins has one.  mahle has one.  tst or something like that has one.  i guess cummins is the best option, but the dealer doesnt have a part # on it.
I would take a flat file and smooth the nicks out of the crank then install a speedy sleeve and order a new seal to fit the sleeved crank. Poor man method would be to clean the nick up with a file and lightly sand the crank with light grit make sure there is no burrs then install the seal.
I don't have much experience with these so I can't comment on which is best. Try calling a cummins dealer instead of the dodge dealer.
lol yea i was doing that as i typed.  cummins was like "we stopped making that in 2007."  i had to get my engine serial number and give them the part number i thought was right (3802820) before they confirmed it was right.  *face palm
this is funny...
http://www.dieselpartsdirect.com/DS3802820
20 dollars... or 124 dollars.... same product descriptions.  man this is so frustrating.
this is funny...
http://m.ebay.com/itm/OEM-Cummins-Front-Main-Crankshaft-Oil-Seal-with-Wear-Sleeve-89-Up-Dodge-3802820-/191768405010?nav=SEARCH
I'd go with this one just because it says cummins on it.
i called.  so funny.  they said one is aftermarket and they are the "same."  i asked if it comes w/ the depth tool.  crickets.
For the money, i will order both.  practice set!
thanks guys.  #frustrated
holy crap just realized ur ebay link!  sweet!
11 minutes ago, Buzzinhalfdozen said:
ur my friggin parts hero man!  i ordered two just to be safe.
would be funny as hell if he put the aftermarket one in a cummins box.  would be my life.
Edited by bms231
I would be on that dealer like white on rice man.  i'd prob drive my truck to the dealer and pull the cover in front of one of the bays that guy worked on.   Then I would drag the service manager out and have the tech explain what you are finding......Even if it was damaged when he started he should have told you.
I would hate to be in your position.    I hope it works out.
Edited by Me78569
I just hope my gear housing isn't cracked.  He had those bolts in over 75ft lbs.  Also got all kinds of ultra black on the threads before putting them in which can cause hydro locking and cracking of the cover according to another tech.
I told the service guy (not manager... that comes wednesday) that this guy basically grenaded my truck.  he literally caused more damage than the truck is worth if he cracked the gear case.
Edited by bms231
wow, that is quite the hack job of a seal replacement. Ive done a couple of these and the second one went so smooth from learning from mistakes on the first one.
If you file those nicks down and clean it up I'm sure a speedy sleeve should fix that. ( I got a speedy sleeve and seal through local cummins dealer.) and you have to use seal that comes with the sleeve, factory seal isn't going to stretch over it.
when installing seal put your timing cover on a work bench and place some wood block under it to support while driving seal down or you will warp it, if it aint already.
a trick I learned when installing back on the gear case is to get four metric bolts about 8"  long or so and use them as studs to help guide cover on ( since its going to be silicon  gasket material on it and you don't want to make a mess of it.the studs also help hold it while sliding seal over new sleeve.
Also a trick I got off another forum is the credit card trick. ( go ask the wife for hers if you can, Ha Ha) take card and cut it length wise, so you have a strip about 1/2" wide the length of card. when you get seal next to the new sleeve just stick card in their and work around shaft as you slide the cover in place.you are just placing the lip of seal in the right position when doing this.
hope this helps
16 hours ago, Mopar1973Man said:
Something to take notice to... Look at the pictures again the seal is installed backwards.
Front side.
That the back side lip.
Backisde...
That is what I initially thought.  I am not 100% sure now when I pulled the cover off I took photos.
Rear of the cover:
this is the front of the cover:
While I am in there........ I have the "updated case" with the step up around the KDP.  Everyone freaks about the KDP and says do it anyways... but really w/ the updated case it is even necessary?
Someone said in his 1999 24v KDP got him.... yea b/c it didn't have the updated case.
i did a genuine cummins speedy sleeve myself on my rebuild as the crank had a groove in it. i used the cummins seal install tool and pounded away to get the seal started and after a bit of finesse it went in. The tool will bottom out on the cover and thats when its seated all the way. Install was easy, with the plastic install tool in the seal, slip it over the crankand push the cover on. Note the seal goes on dry and dust free. I have had no issues with mine since rebuild. It was weeping a little as the groove was pronounced and the original seal was worn.
oh and it looks like the seal is installed correct, but how it was installed (from the rear or with improper tool) could have caused the seal to become warped or damaged allowing leakage. Plus that RTV is not helping...
thanks for the tips.  getting the speedy sleeve on is what i worry about.  no tool to do it other than hammer and 2x4.  the sleeve too i hear is supposed to go on dry.  i had someone tell me you are supposed to use red loctite on the crank shaft before putting the speedy sleeve on to fill in all the grooves and secure the sleeve to the crank.  truth?  i mean makes sense... u dont want the speedy sleeve rotating.
the sleeve i didnt use a 2x4. and i dont suggest using a 2x4. the sleeve will best go on one way and basically gently tap it in a
circle to seat it.  using a 2x4 will get it off center and ruin it etc etc. it took me about 25-30 minutes of gently tapping it on the crank all the way till its flush on the front. then install front seal onto cover and install cover.
iirc the speedy sleeve will have a beveled side and that side goes on first then gently tap it in
circles to seat. if it doesnt go on just a tad at first by hand, flip it over and try to push it on by hand, it should start itself slightly on its own.
oh and locktite on the speedy sleeve, never heard it. its a interference fit (sleeve fits tight on its own) and i have over 3-4000 miles on my rebuild no issues. Also the damper will keep it from walking forward. I highly doubt the steel on steel friction fit will come loose due to the slight friction of the seal.
zoom in on the crank and you will see the thickness of the speedy sleeve. it was about 1/8" thick. the shop installed a speedy sleeve that was paper thin and i removed it and installed the
cummins thicker speedy sleeve with matching seal. i also recommend test fitting the seal onto the speedy sleeve before hand to ensure it all is properly fitting then install everything. "measure twice cut once thing"
Edited by CUMMINSDIESELPWR
