Injector line threads
- Replies 23
- Views 5.7k
notlimah 6 posts
Mopar1973Man 5 posts
Dieselfuture 3 posts
Hawkez 2 posts
3/4" to 1/2" NPT Bushing https://www.fastenal.com/products/details/440024-131280 1/2" to 1/8" NPT Bushing https://www.fastenal.com/products/details/69853 You can get
The mating surface of the crossover and injection line is what seals, not the thread. This is true for more fuel lines in our system. all JIC fittings are like this,
So as I'm chasing down this fuel leak, I was poking around under the hood just to make sure I didn't miss any obvious leaks or that nothing new happened. Well I got to looking more closely at the injector line bolts and it looks like some are threaded on more then others. Here's some pics
theres not leaks or wetness anywhere and last I checked, they're pretty tight. Is this normal or should I pull them off and check for something? I don't really want to ignore this, but at the same time, I don't want create a new problem.
