3rd to 4th gear flaring??
- Replies 29
- Views 11.9k
Mopar1973Man 7 posts
Frankstein 5 posts
JAG1 4 posts
Dynamic 3 posts
It's pretty much impossible to have a 3-4 flare unless there's something wrong with the OD roller clutch... During a 3-4 shift, the OD piston on the back of the "main" case pushes against
Mine has done it twice under somewhat light accel while hauling the heavy camper and gave it a noticeable clunck sound. I scares my bank book . So I'm wondering what to do also. Mig
Remember the TC should unlock during the 3/4 shift. HOWEVER a full flare is not normal. If you are jumping more than ~200 rpm I would be worried about the health of the trans. I am goi
Hi guys, I've just finished my rebuild 47re and it has a flaring shift from 3rd gear to 4th? Would like to know what could cause this?? Don't want to messed with it again!!!!
Thank you!
