More brake woes..............
- Replies 12
- Views 3.1k
Mopar1973Man 3 posts
dodgedieselnewbie 3 posts
Hawkez 1 post
Me78569 1 post
Popular Days
I will rebuild mine from this point forward, but my OEM calipers were in pretty rough shape. Not work the hassle for the $30 I paid for the caliper.
Now this one is doing the same thing? Either the caliper was a bad rebuild and the piston is cocking in the cylinder, the pins the caliper slides on are binding or a hydraulic problem IE: bad hose.
Well... after finally getting the rear brake problems under control about a month ago.. my front started acting up (noticeably) as of yesterday.
When I bought this truck back in September... the previous owner was replacing the front passenger caliper the day I was picking it up. Said it was sticking.
When I had the front hard lines replaced back in.. I think.. November... I had the front pads replaced (both sides - with Adaptive) because they were considerably more wore down than the driver's side as the previous owner didn't replace when he did caliper.
Fast forward to yesterday and today as I started to hear scraping/grinding and felt a considerable pull to the left today. Took things apart this evening and this is what I found... on passenger side.. driver's side look decent
Back side of rotor...
I'm shopping for new pads, rotors and calipers. Does anyone have any suggestions on brands? I'm really getting tired of dealing with brakes...................... Can it be anything other than the caliper? I replaced the soft lines a couple of months ago.
Edited by dodgedieselnewbie
