Codes and more codes
- Replies 37
- Views 11.3k
DocH 11 posts
Mopar1973Man 10 posts
dripley 5 posts
JAG1 4 posts
If you want to move out West I welcome that thought with Gods Blessing as it's better out here for mountains and wide open spaces. But if you do not do everything to your truck that has b
This would be a good thing to ditch. Look up BHAF. They filter much better and you don't have to worry about dusting the motor. P0237 is the MAP sensor. I would try some dielectric greas
Personally, the P1689 could be an alternator AC noise issue that caused damage to the VP44 injection. The P0216 code is either fuel pressure issue or a lack of lubricity and seized the timing piston o
Hello Fellow Mopar Folks!!
Man am I Glad I found this forum!!
I hope I am not duplicating a previous post/topic, but I am one puzzled Guy!
2001(Early Build -Actual Build Date on door sticker=03/2000) 2500 4wd with Vin 6 CTD, Quad cab, 155 inch w/b, 47RE, 161k. Only Mods= Banks Big Hoss Tuner( #62782) that does NOT tap the pump wire, K&N air cleaner, and 4 inch stainless Turbo-back ehaust.
Oem lift pump and VP44 replaced in 2012 with 114k on the odometer
03/16 Thermostat (Stant 14289 190 degrees)
03/16 2nd lift pump ( SPECTRA PREMIUM SP1128 ) @ approx 155k, replaced fuel lines to and from tank with stainless steel
04/16 MAP Sensor (Turbo Boost sensor is what the Mechanic called it)
05/16 Coolant Sensor @ 159k
07/15 THR123+Wire (Throttle Position Sensor)
08/16 Blue Chip Diesel Low Pressure Fuel Warning Kit (shows fuel pressure from lift pump at Banjo Bolt on side of VP44)
08/16 3rd lift pump ( Airtex E7153)
08/16 IAT Sensor (ATS 23)
08/16 Fuel Return Valve (Mopar Brand Banjo Bolt on VP44 - Mopar part # 0501 1824 AA)
09/16 Fuel Pump Relay (Wells 19283)
09/16 DB Electrical New, not Reman Alternator (Part #'s: AND 0272, 56027221AD, 334-1409 56027221AD 13874, 121000-4481) which hopefully will be
installed this coming Sunday.
Regular fuel filter changes ( Hastings FF1260 filter, 5 micron as per Hasting Engineer stated during phone call to Hastings)
I have been running Wal-Mart 2-stroke oil for the last 20k or so
The truck starts and idles fine when cold, but I can put the pedal to the floor, and after about a 3-4 second delay, it will start to Slowly rev up...almost to redline if I let it.
But as soon as I let off of the pedal , even a little bit, it drops back to idle.
Here is a list of the codes I am finding:
3X Ignition Key codes: P0123, P1693
Low-Cost OBD II Scanner: P0237, P0123, P1689, P0216
The Banks tuner is showing a diagnosis code that a Banks Tech Support Engineer called a CAN Bus Communication problem, but it has been that way for awhile, and the truck never seemed to notice it, other than the power was back to what felt like "stock", and the mileage was down from what it used to get when the Banks Big Hoss was working.
I have done the "Dielectric grease" procedure on the electrical connectors I can reach, but still need to clean all of the ground connections. Plenty of diesel in the tank, and I have been in the habit of popping the hood open when I shut down....hoping to minimize the "heat soak" on the various computerized components. In fact My Brother kids Me that I am going to wear out the hood latch!
I am hoping that the new alternator may solve issues, but am hoping Someone has ideas on what is going on!
The Mechanic that replaced the Oem VP44 assured Me that it was a Good Quality Reman VP44, and I have had no reason to not trust Him for the last 13 years, but He passed away and I have no way of knowing who actually re-manufactured the pump.
Doug at Bluechip said it was not one of Theirs...
Attached pics are of the Re-Man VP 44...maybe Somebody will recognize the manufacturer!
Thanks for taking the time to read this!
Ed
PS: I hope it is OK to mention Brand Names...Please let Me know if I oops in one of My posts!!
