I've gathered parts I need for low fuel pressure gauge.  Some parts from Geno's, some Vulcan, some local store.
Have a mixed metals in fittings... I have NPT, alum and brass metals.  Some with flare some without.
Thread locker question...  Teflon tape? pipe dope?  Removable thread locker?
What is your favorite thread locker.
  • Replies 17
  • Views 2.7k
  • Some will disagree with me, but this is the way I do it.    Pipe thread = teflon tape   flared fittings shouldn't need anything.
  • Wild and Free
    Wild and Free
    Loctite has a very good application chart and one really needs to use it anymore with as many products they have on the market, there is really no such thing as a one and done product. This is an olde
  • Buzzinhalfdozen
    Buzzinhalfdozen
    Since W&F brought up proper pipe tape wrapping procedure, I'll throw in a tip grampa taught me when I was a kid.    Hold the fitting in your left hand with the threads looking at you and
Loctite has a very good application chart and one really needs to use it anymore with as many products they have on the market, there is really no such thing as a one and done product. This is an older version of the basic use products, they have a lot more products now.
http://www.loctite.com.au/aue/content_data/311083_7129_Application_Wall_Chart_V10.pdf
If one really wants to drill down into products and specs here is the master product support catalog.
http://hybris.cms.henkel.com/medias/sys_master/catalogsync/catalogsync/9030422331422.pdf
As far as the OP just some basic teflon tape is all you need in your venture, just remember to wrap it in the same direction as the threads from the end inwards although you are dealing with very small fittings so just one wrap is all you need so it doesn't matter much as the tape will be wider than the fittings lol.:thumb1:
Edited by Wild and Free
Hold the fitting in your left hand with the threads looking at you and wrap the tape clockwise. Works every time!
Pretty basic I know but it stuck with me over the years.
Probably be dried up next time I wanted to use it. I can spend the $50 somewhere else
Most of their products are now "anaerobic" which means they only cure in the absence of air, the bottles are even air permeable to keep the product liquid until use so it can ultimately last forever. This is why the product under the cap of an open bottle is dried as it is absent of air.
I wont use Teflon tape unless its the last thing available and there's no stores around with anything else.....  Not only is it hard to work with, easy to leak, but you can only turn the threads in one direction.  Meaning, once you've turned past the point where you "should" have stopped, there's no going backwards because the tape will just pile up and leak for sure.
Any fuel compatible thread sealant is better than Teflon tape.  I've had a tube of Loctite for so long that its cracked and busted open.  Sits in my tool box wrapped up with paper towels, and if I need any I simply scoop out a glob.  Going to get my money's worth.
And.....just as with ANY thread sealant, you cant get ANY on the internal surface.  Thats BAD. :thumbup2:
Permatex® Thread Sealant  with PTFE ( #80632) will work just fine and less than $10 at Amazon for a 4oz bottle.
What I used most recently is some fel-pro with ptfe that I've had for probably 20 years I had forgotten about. Worked just fine.
I'm not sure I see a good reasoning behind this.... The tape isn't hard to work with??? Wrap it around 3 times the right direction.
You shouldn't ever be turning threads backwards.... if you've gone too far with pipe threads it usually breaks one of the fittings. Other than that I've never though I've gone "too far" on tightening one. Only had teflon tape in my dad's shop for the 22 years I've been alive and never had a problem where I couldn't get something to seal.
In the end though, use what you're comfortable with :thumbup2:  I like my cheap tape :)
Well because you've only been around for 22 years, thats why..... :whistle:
No seriously, when I say turn backwards, there are countless times I've had to turn a fitting backwards for being farther than I wanted, or working with two threaded fittings fit together and by moving one you accidentally move the other in the wrong direction or too far.  I dont think I've ever broken a fitting from over tightening either.....
But yes, you're correct, to each is own.  I hate Teflon tape.....you love it.  Thats why they sell both. :thumbup2:
I'll have to second the loctite 545. It's easy to work with, doesn't leak, and I believe I even read somewhere that it won't hurt the fuel system if you manage to get some in there. Yes it's expensive, but a little goes a long way and it's well worth it to have a garanteed once and done leak free joint. Just my $.02 :-) btw I hate thread tape lol. Maybe because ive been using it wrong lol I never did three wraps like @TFaoro said...
I have used ptfe pipe dope successfully. I would avoid using that on something post filter though.
i use either the tape and I have some ptfe pipe dope that is compatible with diesel fuel that i use if necessary. Most brass to steel or brass to brass I dont find any of it necessary. I guess it just boils down to personal preference and whether or not you have a leak.
