Looking for Staff Members
Need a new set more than likely. Going to Getty mine bench tested. But need good information beforehand just in case.
Shed your knowledge on injectors on me. Who to go with and why.
I've heard a bit but need set straight on some things. My DAP set is less than 40k on me and at least one of them is bad. I don't like that idea...
  • Replies 145
  • Views 22.2k
    There was a TSB for early model truck for change out of cross over tubes because it is easy to crush or distort the crossover tubes.   Another thought is that it's possible the pooled fuel i
  • Normally teflon would bother me. If you just put the tape on the threads for the nuts to screw on then it is outside of the fuel system. The threads on those nuts do not seal anything. They allow the
    Bad injector o-ring will leak fuel into the oil just as @dripley said. Bad crossover o-ring will leak fuel out on the intake manifold. It will not leak fuel into the oil. Bad copper washer w
If they were working fine but the oil was growing it could just be a bad O ring on the injector. I had the same issue 5 or so years ago. Put in a set of DAP's version of rv 275's and the are still going strong. I never had the stockers checked out, just used it as an excuse to go bigger.
I had forgotten about the hard starts, but was only speaking of the growing oil. Point taken.:)
So does anyone have a suggestion on who to go with and what brand?
Probably going to go with a 100hp set or the rv275s not sure yet. I'm still leery about what i was told about performance injectors. Which might sway me to the 275s...
Vulcan, DFI, Haley Speed Innovations
Edited by notlimah
I have been quite happy with the DAP 275's. It would be a step down for you since you have been running the 75hp. They were a step up for me and one I will probably step up again. Vulcan has a good rep also. It would be interesting to know what happened to yours with the low mileage on them.
Do yoo know it's an injector leaking or an o ring?
I like ny current setup of getting the majority of fuel from injectors rather than a wire tap.  However, it isnt adjustable.
@Mopar1973Man you can NOT blame an injector alone for morning hard starts just because you swapped yours in. There could have been a slightly loose line, an O ring not seated right, etc.
I do believe DAP makes a good product. I'd be calling Jacob and telling him exactly what happened with the set you have. He might be able to help with what went wrong and where. He might even take in the old ones just to figure out what's wrong and discount another set.
I'm betting there are literally thousands of his injectors out there and you rarely hear about an issue.
I did call dap but didn't get Jacob himself. Whoever it was,he didn't offer up much and didn't have much to say.
It's not like they came with a warranty. But i would have thought a set would have lasted longer than this...
I was directed to dynomite diesel also. They are edm honed or something i guess.
3 minutes ago, Mopar1973Man said:
@TFaoro the only thing I could suggest is pop test the injectors.
Agreed.
Did you buy used? I thought they had a 1yr warranty.
I would call and get ahold of Jacob. Tell them he's the only one you want to talk to. Who were you directed to?
MY DFI injectors have been great so far, but I rarely, if ever, hear anything bad of DAP.
I would call DAP and try to talk ot Jacob.
He can test them as good as anyone and I cant see why he would not shoot you straight on what failed. Could be something very simple. Even the best of the best have an occasional failure. Look at your 53 block engine. You were more fortunate than many were with that. Cant loose anything by trying.
 Just temper your thoughts with this, even with a one year warranty you are 3 years over that. Anything he does to help is gravy and not an obligation.
Like I told @hex0rz to get an independent shop to test the injectors just to verify the that they are damaged in some way. This will just either double prove what DAP has to say or protECT him.
Dynomite diesel is going to bench them for me i think. Going to run them down to them next weekend and see what they can do. I'll call Jacob beforehand too and see if he has anything to say.
There is no expectation from me that Jacob is in any way obligated to fix this. My only thing is im just confused as to why i got so little miles out of them. If Jacob feels there is a defect in workmanship and he wants to do something about it, fine by me.
Any word on what you are hearing on your injectors? I did not mean to seem condescending in my post at all. I just never had any reason to mistrust DAP.  I know if my injectors had gone bad in 40k I would not have been happy either. Even with  my driving I would have been at least 6 months out of warranty. And probably not happy to boot.
I have been looking into it. I called dynomite diesel and they want 30 to test each injector. They'll waive the fee if an injector is bad and you buy a new set from them.
Testing includes putting them on the bench, inspection and setting pressures.
That's 180 dollars i don't want to risk.  A set of 75hp injectors is almost 800.
So i called dap and tried to get Jacob on the phone today. Was on hold for 10 minutes before i hung up...
Should of sent the injectors to Idaho injection tech in Lewiston idaho. Still free to test and get pop values. I think it only 9 dollar an injector for tuning. 30 dollars is way too high period.
