- Replies 145
- Views 30.1k
hex0rz 45 posts
dripley 23 posts
Mopar1973Man 22 posts
jlbayes 8 posts
There was a TSB for early model truck for change out of cross over tubes because it is easy to crush or distort the crossover tubes. Another thought is that it's possible the pooled fuel i
Normally teflon would bother me. If you just put the tape on the threads for the nuts to screw on then it is outside of the fuel system. The threads on those nuts do not seal anything. They allow the
Bad injector o-ring will leak fuel into the oil just as @dripley said. Bad crossover o-ring will leak fuel out on the intake manifold. It will not leak fuel into the oil. Bad copper washer w
Need a new set more than likely. Going to Getty mine bench tested. But need good information beforehand just in case.
Shed your knowledge on injectors on me. Who to go with and why.
I've heard a bit but need set straight on some things. My DAP set is less than 40k on me and at least one of them is bad. I don't like that idea...
