Can anyone solve my mystery clunk
So @KATOOM wants to know more about my mystery clunk.
When unloaded I have a pretty nasty clunk/crash that can be felt in the floor.  Steering doesn't seem to be effected though.   It is directly related to when you unload the front suspesnion.
From the drivers side it feels like it is coming from the passenger side, from the passenger side it doesn't feel as bad.
Before we get into what I have replaced we need to look at the history of my truck, the PO must have broke the front axle as i have a 1994 d60 under the front rather than the 2000 that I was supposed to have on the truck,
Things I have replace that made no difference,
- ball joints, all of them
- steering assembly, 2x
- control arms 2x, upper and lower with new hardware and welding the caster adjuster in place, now have adjustable control arms due to that.
- control arm bushings 3x
- body mounts,
- sway bar mounts and bushings
- sway bar end links front and back.
- wheel bearings
- shocks 2x
- track bar 3x
Things I am wondering about still,
Motor mounts, doesn't happen when I get on the skinny pedal though.
ovaled out body mounts for the control arms.
So who has the magic answer to my clunk?  I rightly dont care anymore. after 4 years of the clunk I just couldn't be bothered to fix it lol.
Edited by Me78569
  • Replies 71
  • Views 14.4k
  • Buzzinhalfdozen
    Buzzinhalfdozen
    Based on what you've checked and replaced I wouldn't think it's a driveline/suspension issue. You should start looking at weird things like: Loose or cracked crossmembers.    Broken spo
  • Damn it ME now I am starting to hear a clunk under my passenger side now. Mostly bumping around on the job. Not so much on the road yet. Everything on my front has got little over 100k on it so maybe
  • Well to add another chapter, I did go ahead and replace ball joints again.     My uppers did have a touch of play in them. I wouldn't consider them bad, but hte alighnment shop did.
Under what conditions are needed to make the clunk?  Small bumps, road dips, curbs, pot holes, etc...  Is there any relation to weather or driving conditions?  Towing or not?  Does it sound metallic or soft and heavy?  Can you audibly hear it or only feel it?  Do you feel it in the steering wheel, under your but, or under your feet.  What track bar do you have and what joints does it have?  Lets get all CSI on this bugger..... :thumbup2:
If its an auto tranny I had this issue with all three of my 2nd gens and it wound up being the shift rod that runs between the body and the frame on the driver side gets dry and makes a very annoying clunk in the floor board area by the sheering shaft. It is a simple ball socket type connector that just needs lube and it has taken care of it on all my 2nd gens.
Man I do not miss chasing constant issues of the 2nd gens anymore.
Edited by Wild and Free
Pretty much all bumps,
Loaded truck clunks less.
It is a metallic clunk,  both hear and feel nothing in the steering wheel
Feet mostly for feel.
Dana ball joints and %100 rayebestos steering and track bar.
W&F I will look at that.I did do all new bushings on the shifter linkage.
Will the clunk not go away if you just turn up the radio?
with truck not started have someone turn the wheel back and forth hard and watch the track bar upper and lower connection. Mine did this and we tightened the lowest knuckle bolt with an impact and went away. The one down on the axle housing is where you won't see much movement but has definite clunk.
I guess if I had replaced my track bar 3 times like @Me78569 says and still had the clunk, I might have to rule it out.
Mmmmm.....not sure I agree with that.  Because not only will the bottom track bar joint unknowingly slop around if its not tight enough, even though its thought to be properly tightened.  And all joint fittings besides the poly joints will bang and clank in very little time of use.  Heim fittings are notorious for this quick wear slop too and even Johnny Joints will loose their ability to remain quiet if they're not greased right and tightened occasionally.  So yes, track bar can still be an issue.
Nick, mine also does the same thing going down the highway, doesn't matter if it's 10mph or 70. Every little bump or load of the shocks/springs I get the clatter and thunking on the floor board, I have also done most of what you have stated above, balls joins, redhead steering, tires,  pretty much all new front end rebuild from Les Shawb, I remember it did it before the rebuild also. I don't get it when I'm loaded down though. I have searched and searched and searched more, and have came upwith nothing, my only thought is the coil springs? The one thing that I have never checked. Or my motor mounts
Edited by fuze24v
You have an auto as well..................putting a pattern together here. Have you checked the shift linkage rod like I posted about above?
I have thought about the coal springs also, maybe the rubber isolators are bad?
Track bar is tight, check and rechecked, even used a jack to tighten the bolt down haha.... I've had someone crank on the wheel back and forth and I watch the track bar.
It is a Rayebestos pro track bar along with all the other parts under the truck.
Replaced all of the bushings in that assembly haha.
I can see it happening if not installed properly. i have had the clunking twice and both times the track bar was shot. The upper joint was just worn out. I guess I am putting faith in @Me78569 installing at least one of them properly.
Not a bushing issue its a dry part issue. I never replaced any parts in any of mine just needed to lube them up every 2-3 years or so and the clunk disappears. Not sure what parts there are to replace, its a ball & socket no wear parts in it that I know of, you may be thinking of another part than I am.
What PN are you talking about so I can make sure we are on the same page.
I would agree to that.....
I regards to the clunk, Me have you checked the front driveshaft?
Missing emails get lodged in there somehow?!
Im all seriousness, I'd lean towards a spring and perch issue. Possibly spring is slightly shorter on that side and slightly coming out of place causing the noise.
Could this be caused by a cushion, isolator, or bolt at one of the body to frame contact points?
The two areas I lubed were the parts broke out in the circle and the ones on the horizontal linkage #4,5,6.
It is a "larger" clunk from a component with a lot of mass or weight behind it, or is it a "smaller" clunk that sounds like something lightweight tapping?  Meaning, like someone is under there with a 10 lb sledge or with a big screwdriver?
And is the noise audible enough and often enough that your can video the clunk? :thumbup2:
