Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI:
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 379.4k
  • Quadzilla Power
    Quadzilla Power
I dont have an adrenaline yet, unfortunately. Do you think the reading would be a static 3.3x so we could divide by 3.3x and always get a presumably accurate reading?
Edited by rogerash0
Just looking at new 2.7 release with boost offset, says for later trucks. Guessing that's why I'm seeing 10 psi on mechanical gauge and 6 on quad. How does this new feature work. Just put number 4 in that option?
What does it read at idle?  That's what you want to input in the boost offset.
Edited by Me78569
Which version are we suppose to be using.  I see 2.5, 2.7 and a couple of test versions?
Ive been using 2.5 I think.
If I'm thinking correctly then 2.7 should have them all included
At idle it's between 1 and 2, so safe to say put 2 in there?  Is it affecting mostly canbus tuning
set boost offset to 0, see what your boost reads, then set boost offset to that amount
So which version are the lay users suppose to be using.
2.5 seems to be the only one that doesn’t have a “test” behind it.
2.7 has “test” in the title.
3.??? Says Quadzilla only.
I like the looks on the 3.?? Version that you can adjust boost (mine is off) and the mpg piece.
I also noticed today that my get are about 100f lower then my analogue gauge
2.5 is the user profile.
The 2.7 and 3 are test profiles for ensuring a bug free release, bug free laughable.
@Me78569 I might have asked this already but does latest version include all of the other versions in it and all the bug fixes or does a guy have to load each individual version one at a time until he gets to the latest version. Say for example I just bought a quad and it has old school comp 2000 on it do I need to load 2.1, 2.2, 2.3, etc till I get to the last one or do I just load 2.7
Thanks.
Just loading the most recent flash will get you set up, unlike windows, where a fresh install needs about 500 updates, haha.
somehow I posted in the wrong tab :o excuse me
Edited by rogerash0
the pump gets a 0-4096 command for fueling, then decodes that into a pulse for the fueling solenoid.
that overhead you are talking about is what wiretap does.  the limit is ~%20-%25 more duration from the solenoid.
But really we are talking about reinventing the wheel here, why not just get bigger injectors?   Bigger injectors effectively increases the amount of fuel injected in the fueling pulse.
Hey, im reading about the new flash/update with the boost offset.
I have the hardfuel.exe 2.6.1 flash, is there anything else i need to update? Maybe redownload the app? Or am i good? The app version i have is iquad 1.9.39
I believe that is the most up-to-date version of the app.  So everything will work fine.  You should be good to go.
I've never messed with boost offset and my quad reads correctly in my 01.5.  I am at 6100 ft elevation however.
2.6.1 does not have boost offset.  Beta 2.7 does.  The vehicle profile for the app is not ready yet so the boost offset is not public.  I dont know if it will be public or not.  It might be more effort than it is worth for training.
Im using version 2.4 V2 Dodge 1998-2000
Should i switch to version 2.5 V2 Dodge 1998-2002??
Yes switch to 2.5,  that will make your tunes exportable and importable from the tune builder excel macro @Carbur8tr built
Edited by Me78569
