Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 362.2k
  • Quadzilla Power
    Quadzilla Power
1 minute ago, KBecker443 said:
It’s my daily driver I mainly just use it to monitor everything still working on the whole custom tune thing to help the truck get better MPG and lower egts
Like @Me78569 will say that most of the MPG is based on timing.
Lower Engine Load = Better MPG
Lower EGT's = Better MPG
So don't get tunnel vision and listen to more timing is better. Make sure you measure your engine load in the same place on flat ground travel and change your timing in small amounts. If the engine load is rises then your going the wrong way.  If the engine load is going down you going the right direction. Keep going till you find a light rise then back off.
@Me78569 any chance you have a tune that will get me going in the right direction? I’m sorry I’m not to savey with the tuning aspect of everything, I’ve ran the basic QZ tunes for the past 6 months, and have a HemiFever tune for my other truck. I’ve done no actual modifications to any tunes or curves
4 minutes ago, KBecker443 said:
Does anybody know who has the OS system and uses the radio as their monitor? Really like this idea and was looking at upgrading my radio and speakers any ways. Hoping I can kill 2 birds with 1 stone
ios works over WIFI, I dont know how you would get that to work.  I also dont know of any IOS head units.
I dont know anything about your truck.  Mods etc etc.  Have you looked in the tune download section?  I built 20 or so various tunes
@me78569 any chance if I sent you my trucks mod list you could help get me on the right path? In the general area at least so I can work from there I'm in no hurry i just know a good tune would definitely help with towing and DD
kzimmer isn't the only one that got it working on an Android stereo head unit. His is definitely a weird case though. I built him a custom version of the OS to try and get the export to work but it still doesn't. No idea why either.
As far as the iOS version is concerned, I believe that there are some head units that will do something akin to screen mirroring from your iPhone. The touch only works on the iPhone, but it will display on your stereo head unit. If someone knows a better way to get it working for an iPhone lets us know.
  • 3 weeks later...
What is the power reduction setting? You guys have it in the first page. I dont see it in my adrenaline. What the heck?
i didnt see any smoke tunes or lope tunes for the v2. Any links on the site? Just for fun. Not for DD
Won’t find those here for download. We may hint how to build one every once in a while.
Edited by trreed
Won't find any here... Everyone is creating clean performance tunes or clean economy tunes. No one has bothered to create a lope tune or smoke tunes. Just attracts a bad crowd and typically a turn off for everyone.
Actually, there is one tune up on the download area designed to overwhelm TM that would do what you’re asking @Raffron
I really dont want to piss anyone off. Just to play with while at the mud bogs with the big boys and their toys. I agree smoke is what gives diesels a bad wrap.
i dont see a torque management tune .
I see it... Thanks. How do I load this ADR9802V2.7 MPG Release Final 2.7.7
Look at the “how to import/export custom tunes” topic on the main quadzilla page
Once you read the articles and posts about custom tuning, you can build your own tune to smoke as little or as much as you like. As far as the lope thing goes... This isn't a 70's big block carbureted gas motor with a custom cam. Lope isn't a thing. At least not a proper thing.
However I started my truck today after a -20° C day and it wasn't plugged in, and it loped a little. I could help you source some dry ice if you'd like to try to recreate this scenario... Since there aren't a ton of 1st world inhabitable places at this moment with this particular temperature.
285 75 r16. Does anyone know this in inches? Thanks
32 Inches... Basically gaining 1 full inch over me. But more rotational weight...
285mm = 11.2205 x 75% = 8.41 inch x 2 =16.83 + 16 Rim = 32.8 Inch tall tire.
Just like 235/85 R16...
235mm = 9.25197 x 85% = 7.86 inches x 2 = 15.72 + 16 Rim = 31.7 inch tall tire.
Or 265/75 R16...
265mm = 10.4331 x 75% = 7.82 inches x 2 = 15.64 + 16 Rim = 31.6 Inch tall tire.
Or 265/75 R16...
The iquad minimum is 95. 7 inches. Not sure how they are getting this number
