Issue that has everyone stumped!! Rough Running truck
- Replies 75
- Views 22k
I really hope that was the problem. Mystery gremlins sure are a pita.
You can take off the shaft nut on the timing gear and then using a puller, pop the gear loose from the shaft. The gear wont come off but with a mirror and a bright flashlight you can wiggle the gear
It doesn't come off but merely pops loose, so there's no way to be off a tooth unless it was installed that way. The nut torques back on at 125 lbs too.
My truck runs rough at idle, any throttle position, unloaded, under load, doesn't matter. Now it is NOT a cylinder misfire. However, it does seem to sound consistent when i enable 6 cylinder high idle. You can hear it and feel it in the truck during high idle (you can even see it in the mirrors. I have tried to take a video but it doesn't really show up well because the truck is just so loud. Now in 6 cylinder high idle (at 1200) rpms the "miss" is Consistent but about once every second or so. How can this be?! The whole fuel system seems to check out. Fuel pressure is all normal. Still have great fuel economy and power. There is usually a heavy lope when cold, then clears up when driving. If you listen to my truck from about 100 feet away, you can hear it running strange, like its not firing consistenly. When im cruising going 55 and let off the gas SLIGHTLY (so little load on engine), the truck starts sputtering and can be noticed on tach (+/- 50-100 rpm). And when coming to a stop (no throttle), it will sputter the same way until i get to a complete stop where you can hear the truck lope (SLIGHTLY) at idle. I have taken it to the dealer twice, cummins once, shown two other diesel mechanics...and they are stumped. The ONLY thing I can think of is a new harmonic damper. I ordered an ati damper to see if it helps. I hate to throw a part at it but Im at a loss. If anyone has anything I can work with please help me. I can't drive it till i get this thing fixed. Ill try to get SOMETHING for a video but...
