What are the best headlight packages?
In search of new bulbs and headlight assemblies. What are the best combo packs for those dark nights? And winter nights..  LED'S or HID's? Preferably something that isn't going to cost a fortune. Amazon works the best.
Drop web links, please.
  • Replies 46
  • Views 10.4k
  • I put the same blubs in my son's Volvo.  They lasted 4 years of college and at least a couple of years at home.   They cost me about $10 each from my supplier.  EBay has them for $12.
  • My non-sport head lights are plastic.  Here's a pic of one after I cleaned it.
  • I use Flosser 9104 blubs. they are a direct fit replacement for the stock 9004 55 watt blub and for the low beam in the sport headlight.  These are 80 watt low beam and 100 watt high beam.  This is a
I put oe style new lenses and bulbs for $75. Now that not a fortune. I know thats not what your after but the new lenses made quite a difference.
I use Flosser 9104 blubs. they are a direct fit replacement for the stock 9004 55 watt blub and for the low beam in the sport headlight.  These are 80 watt low beam and 100 watt high beam.  This is a cheap way to improve the lighting out put.  I've been using the same blubs for 11 years.
Whatever you do don't get cheapo housings from Amazon.  OEMs have a better reflector.  Issue with OEM is simply the bulbs are halogen which are limited by gas to ~500 lumens( I think)
Hotter bulbs put out more light at the expense of shorter life.
Personally I recommend retrofitting projectors and hids.
Whatever you do don't put hids in the OEM housings without a projector.  The housing was designed to reflect light from a build with a filament, using hids in a halogen housing will scatter light and it will blind people.
How long do the bulbs usually last?
Edited by IBMobile
Sport housings with a bought or home made brite box.
@Hockeyfm13 I believe I derailed your thread on what you are looking for. It would appear that @Me78569 might be your man on what you are actually looking for. All I have ever had is the oe style.
Is the Flosser brand important?
IB, just making sure I'm understanding what you're doing.....  You've installed these in the Sport headlights or the non-Sport headlights?  Reason I ask is because the Sport lenses are plastic whereas the non-Sports are glass.  :thumbup2:
Not to get off topic..but I miss the JW Speaker's on my JK.  I kept my lighting before I sold the vehicle....just waiting to use them again someday.  I am also in the market for a set of housings for my 98.  Too bad there isn't an American company who manufactures a nice set of housings.
Edited by sooxies
Well dang fellas.....I learned something new here.  I was always under the impression the non-Sport head lights were glass.
So then I guess the intent of my original question to IB was whether or not there was any issues with heat and the plastic lenses using the higher wattage bulbs, but I'm guessing that would be a big fat nope. :thumbup2:
