- Replies 25
- Views 16.4k
I think SPR is Spicer Life Series® U-Joint with the P9 FG, HN being production code.
I read since i did not know anything about it. Thought I would post for the less educated such as myself.
He did.
Hello Everyone,
My truck's two piece rear driveshaft was very worn after 172,000 miles (doh), so after speaking with a couple of driveline shops I selected one to build me a one-piece aluminum to replace the two piece. The shop required u joint size confirmation so after pulling the rear u joint straps, i measured the caps/width & came up with 1410 ujoints. The shop didn't seem phased that i had 1410 u joints (said could have 1350 or 1410) but surprised since I thought all D70's were 1350.
I continued my investigation and after more web research concluded I may have a D80 Hybrid (like the manual trucks) based on the diff cover bolt pattern. The ID tag doesn't say so maybe someone can shed some insight? While some will prob say "no way" i did find some threads on the net of claiming D80 hybrids in auto powered truck but nothing conclusive.
The truck i own did come from the factory ordered with the heavy duty package (suspension & drivetrain/241DHD trans) along with the camper package. Could someone post a picture of your D80 hybrid for me to confirm?
Edited by NightHawk
