Bleeding Air from Fuel with No Start
- Replies 13
- Views 5.6k
BigPimpin 3 posts
Mopar1973Man 2 posts
dripley 2 posts
JAG1 2 posts
Popular Days
I normally slide the entire line nut out of the way so I can see the fuel spray from the driver seat. This way a single man doing the job can see if its pumping or not.
I cant help with the Adrenaline, but it would be good to turn your FP up a little more. It is best to see 14psi minimum at WOT. That keeps max fuel flowing thru the pump for cooling. The fuel also lub
I've looked up all I could about this, but I really need some quick info.
I replaced my fuel line from the filter to the VP44 with an upgraded fuel line. After the install, I tried bleeding the lines by cracking the number 1, 3, and 4 injector connections. I got fuel to the number 3 and 4 lines after a couple of bumps of the key, but number 1 won't bleed fuel no matter how many times I try. The truck won't start.
Could I be doing something wrong, or is this a sign of a bad VP44? Any suggestions?
