Quadzilla Adrenaline Economy and MPG
Since @Me78569 and company have the tuning thread for performance side. I'm going to start the ecomony and MPG thread for the Quadzilla Adrenaline. I'll be posting up my MPG logs and all data I can provide of what I've got going on. I've been keeping hand math logs of all fuel purchased as well as my tablet running OBDII link LX and data logging from that direction too. I'll share my tunes and settings as well.
QUADZILLA TUNES CURRENTLY LOADED (Check back often file is updated at random times)
Quadzilla Ardrenaline.xlsx
  • Replies 431
  • Views 159.2k
    Finally!!! Yeah!   Broke 21.06 MPG. Finally got the tuning figured out. 297 miles and filled up with 14.096 gallons giving me 21.06 MPG. This is still with winterized #2 diesel and winter co
    I've learned a lot so far.    Light Throttle Load Limit (Percent) - Mopar1973Man Suggested Setting 25%   This value should be built around the 65 MPH speed on flat ground. That is
    Now that I've returned to the wiretapped crowd now I can see the difference between CANBus only o Wiretap. Of course, the power is way better tapped but I want to find out if I can reach higher like I
6 minutes ago, notlimah said:
Yea and just because all the conditions are perfect for one tank of gas doesn’t mean that’s what kinda mileage you get.
Ummm... No wonder your MPG suck if you are putting GAS in your fuel tank no wonder it runs like crap. Seriously. My old logs from back in the day with my +50HP injectors and Edge Comp with cruise set at 55 MPH I use to get 22-24 MPG pretty constantly. I gave up my Edge Comp moved forward with the Quadzilla and never reach those numbers again. There is other factors like my original +50HP injectors from Vulcan died at 75k miles with misfire issues (pop pressure fell), then I lost the awesome VP44 pump that nearly made 250k miles. So now I'm rebuilding and attempting to reach my old averages of 22-24 MPG like the past. I want to beat my old high mark even by +0.1 MPG which is 27.2 MPG (hand Math).
Gas/fuel/diesel/petrol whatever you wanna call it, still missing my point.
Not really. I realize the limitations. You would have to EXACTLY perfect conditions to hit that high mark. Yes you won't be able to hit that every single day. Like my old data logs I could hit high number as long as I stay focused and never towed trailers or hauled heavy cargo. But I've done it in the past and I want to do it again with the Quadzilla and the new knowledge we have now.
Now driving on this tune for the last few days I'm very pleased. Cruise engine load is reduced at least 10%, EGT can get really low at times dipping into the 400°F range. It very shock to see timing touching 24° while in 4th gear at 55 MPH winding through the canyon. Now the Quadzilla instant MPG floating 27 to as high as 40 with the roll of the highway.
@Me78569 I know you mention about the pump might of been a freak of nature but I started thinking about the basic functions of the VP44 pump and realized that fuel volume is based on plunger and cam ring (lobe height). Timing is based the cam ring position and shaft key. What if there is range of timing that is considered OK? What if my current pump was more on the retarded side? Fuel wise I can pump more than my turbo can handle. So this comes back to timing.
So spent few day measuring max advance of my VP44 duri,g normal road condition. Now adding 1, 2, or 3 degrees and what the results.
Its true with advanced timing... EGTs will fall, boost will drop, engine load will drop, and coolant temperature will rise some.
Yea I would see minor amounts of differences on the test bench that are acceptible.  That's why they have the key.  There are still things like mechanical efficentcy that come into play as well.
I am still guessing best mpg happens above 20* of timing.  After watching the OEM timing and then watching what the edge does it only makes sense that timing needs to be high for good mpg and to match conditions prior to the quad for you.  I would not be surpised by 22*+ of timing.
On 5/20/2018 at 5:04 PM, Mopar1973Man said:
Sure wouldn't do much for making compression or boost. Somehow diesel doesn't burn very good without air. :think:
Need to ask nasholes how they do it in space, they have an answer to everything
A sh*tload of volatile fuel!
Edited by trreed
Actually a crap ton of Oxidizer.
Quote
On this slide, we show a schematic of a liquid rocket engine. Liquid rocket engines are used on the Space Shuttle to place humans in orbit, on many un-manned missiles to place satellites in orbit, and on several high speed research aircraft following World War II. In a liquid rocket, stored fuel and stored oxidizer are pumped into a combustion chamber where they are mixed and burned. The combustion produces great amounts of exhaust gas at high temperature and pressure. The hot exhaust is passed through a nozzle which accelerates the flow. Thrust is produced according to Newton's third law of motion.
How's that tune been? Think you'll update your uploaded one?
Like another thing I'm finding out is that you need to consider the IAT temperature in your tune. Being I've got wild swings in temperature starting as low as 48-52*F IAT as I roll out in the morning through the canyon. Then by the time I'm returning home I could be as high as 125 to 130*F IAT and find myself moving all the bands of timing up and down to keep a sweet spot. Cooler mornings you can run more timing by the heat of the day you need to retard this some.
With the smaller tires, the EGT's have been low. Engine load is low too like around 15-19% at 60 MPH on my last trip home.
Also going to split up the tunes again.
Read your entire topic, read some others here and there when I want to read, you've had a tough time with this economy deal over this year or so. What's your elevation on your route for moms dialysis? At sea level in my dually 4wd tow rig I've been averaging 22.5 handcalulated (odo and speed calibration to .1mph) on empty drives and 17-18 towing another dodge, weight :9200lbs GVW. And honestly there is hardly anything done to it besides general bolt-ons. I'd like to interject some info I think you and Joe Dirt over there may have overlooked...
2,800 -> 4,400 -> 2,600 roughly. So the entire trip down is downhill following a river. 3 grades to climb. Then the whole trip back home is all up hill. Home is 2,800 feet elevation so I climb out the hole to get to New Meadows, ID then drop downhill following Weiser River the whole way. The only 3 grades (Fort hall Grade, Mesa Grade, and Midvale Grade).
My god your both fast to respond lol, Excuse any errors guys, new to your forum setup. Must say I like it better then cummins forum.
This info is for both Joe Dirt (I love the pic haha) and Mopar man Ok so your not as high as I expected... first let me grab some info, I assume your a manual truck with a 3.54 ratio based on the info you've provided on rpm @ speed. Do you run a fass style fuel system or some custom collaboration for VP health? Besides the obvious quad, exhaust and injector what else outside the factory realm is done to the truck? That's for both of you, I'm curious on some things before I open my metaphorical mouth...From personal builds of customer trucks as well as my own I've rarely been under 20mpg except for race day or towing...
