- Replies 77
- Views 26.7k
Me78569 21 posts
Tavo24v 12 posts
Youngblood24v 10 posts
Mopar1973Man 8 posts
I couldn't believe the few small boost leaks I had after i fixed them how much different it was.
app-release.apk There yo ugo. the beta app has a tune loading screen that helps tell you what is going on. The difference beyond that is nominal. either will work fine, the
this will migrate to the standard version. The fueling hand off is nicer. mpg stuff is pretty dang close honestly. It uses the fueling duration( amount injected) and rpm to calculate instant mpg.
ADR9802V2.7 MPG Release Final
View FileThis is the final release for the 2.7 V2 tune. It includes mpg meter and mpg trip meter. This flash also includes a better handoff of control between the ecm and the Quadzilla. Run this with the Quadzilla vehicle profile V2 1998-2002 version 2.5
Edited by Quadzilla Power
Changed the Name of the File (Using revisions system for updates)
