- Replies 76
- Views 12.3k
Mopar1973Man 11 posts
dripley 11 posts
Countyguy 11 posts
Me78569 10 posts
Countyguy- I got my ECM from Flight Systems Electronic Group. They rebuild these ECM's 100% and stand behind them with a 1 year warranty and unlimited mileage. Here is their website https://www.fseg.n
Just an update to all. Thanks for the help. I ordered my Ecm from Flagship One out of NY. Installed last night and all is good. My alternator was rebuilt by a local rebuilding shop called Fondy auto a
Absolutely agree with above. All I am saying it is so difficult to have a hard and absolute rule that a particular trouble code means an absolute particular hardware failure. Often it can be inciden
Hey Guys, New to the Forum, but not new to Cummins diesel trucks. I limped my Cummins home on idle as this is all it would do. 2002 Dodge Cummis 4x4 6 speed manual. Basically stock, except for Smarty programmer and Airdog 100 fuel pump along with pillar gauges to monitor.
Host of codes showing up when I read them off my Smarty programmer. I swear I have a bad ground or something of that nature, but I don't know where else to look. I'm almost at my wits end!
Things I have already done:
Cleaned battery terminals both batteries.
Replaced APPS with Timbo
Replaced MAP sensor-Factory Cummins part
Replaced IAT sensor -Factory Cummins part
Truck will not rev. up. If it does it will only rev. for a few seconds then "cut out". Rough idle like never before.
CEL light lit up along with temp. gauge going "crazy" right to 240 degrees at "start up" then goes back to "zero" back and forth. Then "Check Engine " light comes on and goes off.
These are the codes I'm pulling:
P1488-Aux. 5 volt too low
P0606-ECM failure
P0575-Cruise switch failure shorted
P0342- Dont know what this is?
P1286- Don't know what this is?
P0562-Charging system too low
P0117-ETC sensor too low
I don't know where else to look or do? I think I have a bad ground somewhere? Please help. Thank you!
