Verifying HX35/40 turbo size
I got a turbo from @CSM and I went ahead and got it pulled down to rebuild it. While its apart I figure I would measure out the turbine and compressor wheels. Here is what I got.
Compressor
Inducer 60mm
Exducer 83mm
Turbine
Exducer 60mm
Inducer 69mm
From what I found online this is a HX40 compressor wheel. The HX35W is 56mm compressor wheel. So this should be a rather nice boost (pun intended). Waiting for my bearing kit to come.
  • Replies 81
  • Views 32k
  • Yep, sounds like a HX35/40 hybrid with a 8 blade compressor.   Me thinks Mopar1973Man has caught the the power bug...
  • So fun fact of the day, there are two different versions of the HX35.  The 8 blade HX35's were 56 mm.  Then, Cummins quietly switched to a 7 blade version that's actually a 54 mm inducer.  I found thi
  • Mike was talking about checking his stock turbah, that's where my comment originally meant to apply.
7 minutes ago, Me78569 said:
@Cowboy  vgt lalala   :)
You've got studs and springs. I think it's time for you to step up to VGT compounds! :stirthepot:  We could build the piping and support bracket easliy.
i'll let you tell my wife why I need a new trans :lmao:
I've got an nv4500 sitting in the shop waiting for a new owner! Just needs a countershaft, gear, and bearings....
I'm taking donations for a trans in the 12v. :lol3:
Can someone help me out...
Are all turbo sizes based on the inducer measurement? ie: a 62/65/12 and a 62/74/14 are both considered 62mm turbos?
65mm turbine vs 74mm turbine on the exhaust side. Then the exhaust housing going from 12cm2 to 14cm2. So, the second turbo would Have more lag.
Yea but are they still both considered a 62mm turbo?
Yes they would both be 62 mm turbos.
Correct, there is a lot more to a turbo size than their in/ex numbers but its a good ball park.
Thanks. I'm understanding the turbo sizing a little better now.
And then we get into turbine design. Compressor cover design with changes in diffuser. Goes down hill quickly lol
So why don't we discuss this so someone might create and article about turbos?
I do not know enough about it to do that. Just some stuff that comes up when Weston texts me.
Aight, I'll start putting something minor together. I haven't seen it on here but do you know if anyone has pulled the basic info on sizes from one of the other forums?
I'm impressed with the minor change in how the turbo runs. Highway cruise boost pressure is down I'm like 2-5 PSI at 65 MPH and now with the +75HP injectors my EGT's have dropped a good 100*F so 65 MPH I'm floating 500-600*F. Max boost I was able to bang out this turbo so far was right around 47 PSI with my old Quadzilla tunning for the stock injectors but it was way hot and smoky.
Those are good numbers!!
How does the pop pressure compare to stock?
47 psi with timing and stock head bolts??? I'd dial it back or plan on studs asap. With the change in turbine the 47 psi now could be the same as 50+ on the stock turbo.
300 bar vs. 310bar (stock)
Already done in my tuning. I'm max boost is now like 37-40 PSI I cut my maximum fueling off by about 10% and made it long shallow curve for towards the max fueling. Again majority of my travels are mellow cruise control 2-5 PSI. Very Very rare do I run hard on it. I need reliability more that racing performance.
Again... I've got to travel 4,000 some odd miles every month. Not about racing... Just about getting there on the cheap fuel wise.
