- Replies 33
- Views 5.7k
Milam_11 10 posts
Mopar1973Man 7 posts
SilverMoose 5 posts
Killer223 2 posts
Typically these trucks come with 3.55 gears the other option is 4.10 but you won't be pulling at 80-90 MPH at all. Like my truck at 80 MPH is 2,400 RPM with 3.55 gears. Highly dou
Fresh oil change today, runs great. Used to have an edge comp box on it now it doesn't have anything. Trying to decide between a comp box and a quadzilla. Any help would be great. Not looking to moles
If the cover is off there is no reason to count the teeth. The ratio will be on the ring gear lol
First off thanks for the add. Looking at buying a 2002 Dodge. Guy said everything is great but one problem. The owner now said you can cruise pulling a trailer at 70 all day but Rpms are to high at 80-90. I found the Guy who built the truck and said you could run 120 no problem before. Any guesses on what may be causing this? Truck is mildly built with a fully built trans. Below is exactly how the owner now worded it
I it won't run 80-90 on the highway but I pull the camper 70 all day. It runs too high of rpms in the short. U can hear it hit overdrive but only drops 250 rpms. It doesn't burn fuel I get about 18- 19 pulling.
Witn this being said any ideas? I've searched around and from what I've read it could be a bad solenoid? Would like to have an idea of what it could be before I purchase it. I've always had fords or duramax so want to give this truck a shot. Any help is appreciated, thanks again!
