- Replies 54
- Views 13.4k
Dieselfuture 19 posts
AH64ID 8 posts
dripley 7 posts
Mopar1973Man 6 posts
Unless you go Dexter EZ lube axles. Bit of difference where this design allows you to pump all the dirty grease out where pushing grease into the ABS hole is bad idea because you can
I have counteracts in both sets of truck tires and am very happy! I ran centramatics for a while too they are just as good. I only removed them because of issues on rotations with Les Sch
Ohhhhh. I'm so used to Minnesota vehicles I looked right past that! That rust isn't bad at all. You still have paint on most of it!
Alright I know it's been brought up in past, now that more time gone by I'd like to hear more on ways of balancing tires. Mainly I'm interested in people that use balancing beeds like counteract. I used them in trailer before and honestly couldn't tell you the difference as it never gave me problems before. I also used it in a suburban of some one I know and rode in it with good results. I am now thinking of getting rid of waights on my truck and using them. My few year old wheels are starting to get that aluminum corrosion under waights on wheels so I want to use beeds jus need some more imput.
