Custom Quadzilla Tuning R & D Thread
I didnt want to mix up the threads by posting unrelated information so I figured I would start a new one.  This thread is for figuring out what works and what you find your truck likes.
I did some more datalogging as of late and found that a more aggressive timing curve later in the rpm band, say 2500 + rpm, seems to pull harder up top.  Previous I was running tunes that maxed timing at 26*.  I took 2 tunes copied them and ran them back to back on the same stretch of road, same conditions.   I was not using wiretap for this so I will leave those details out
First Tune 29* max
Quote
Race 29*
Number of Power Levels 6
RPM Limit 3700
Valet Mode
Maximum Valet Mode Power 35
Timing Parameters
Fuel Load Timing 1
Low PSI Timing Reduct 5
Timing Reduct Scaling 80
LightThrottle Timing Adv 1
Light Throttle Limit 35
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 24
3000RPM 27
MAX 29
Boost Level Fueling - CAN Bus
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
Second Tune 26* max
Quote
race 26*
RPM Limit 3700
Valet Mode
Timing Parameters
Fuel Load Timing 1
Timing Equilzer
1500RPM 16
2000RPM 19
2500RPM 22
3000RPM 25
MAX 26
0 PSI 88
1 PSI 90
2 PSI 92
3 PSI 94
4 PSI 98
5 PSI 102
6 PSI 106
7 PSI 110
8 PSI 114
9 PSI 118
10 PSI 122
11 PSI 126
12 PSI 130
13 PSI 134
14 PSI 138
15 PSI 142
16 PSI 146
18 PSI 150
20 PSI 150
22 PSI 150
24 PSI 150
26 PSI 150
28 PSI 150
30+ PSI 150
The interesting thing is the tunes are the same except for the timing above 2500 rpm.  If you look on the graph rpms hit that 2500 rpm mark at about line 20-21, each line is ~.3 seconds so 3 lines = 1 second.    You can see where timing jumps and also where boost jumps.
Now keep in mind the graphs are not exact so take them with a grain of salt, but everything appears to show that the tune with higher timing up top gives faster time to 50 mph, and a faster ramp up of boost.  The higher timing tune appeared to reach 50 mph nearly 1 second faster.
as always studs are a good idea, but I am fairly sure anyone can run this timing above 2500 rpm.    If people are not blowing their heads off left and right with other tuners then there is no reason why this type of timing curve will hurt with the Quadzilla.
Food for thought, open to other thoughts.
  • Replies 477
  • Views 89.3k
  • and a spare room for me to crash in while I tested about 50x different tunes and setups hahaha
  • Close your eyes and click it.  That's how I order truck parts these days.
  • I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways
22 hours ago, Dodgeih said:
I can see that side too, but it's not that much different than the same Joe Blow that wants to run 300 horsepower injectors on his otherwise stock vp44 truck with no lift pump or upgrades of any sort. That happens almost daily
I can tell you right now Weston will not sell to them.
17 hours ago, rogerash0 said:
Don's f1 220hp injectors in my truck with a 2-300rpm lower than stock stall converter (see firepunks site) will stall my truck when put into reverse when cold. I throw it into first, then reverse, and it won't stall. Typically just needs to do that once unless it's real, real cold.
Don likes 7x.010 nozzles. If you let it run for a few min it should take care of the stalling without having to pull the injectors.
Yeah, you're probably right, but with that being said, the seller could help the buyer decide if a higher pop is needed, acceptable for the application and ultimately decide if they are willing to sell to the buyer, just like many do now.. Just like most tuners won't sell a 250hp tune to a guy with a stock truck, although it can add more confusion and make it more difficult, especially in an industry that everybody already knows everything...
@jlbayes
another off the wall theory I have been thinking about.   We all accept that increasing pop decreases duration.  therefore when the ECM reacts to something, stalling, the resulting commands should be "dampened"...Correct?    IE if the ecm thinks it needs to spike fueling by %20 to keep the truck alive, the resulting fuel spike might only be %18 if pop is significantly increased.
So say I am correct in thinking that the stall issue is actually related to the sharp pull in fuel after the first increase in fueling as a result of being put in gear.   ( my above post step 5)
The increased pop should actually help keep the motor alive.  Now this would only be the case when injectors are big enough to cause that first spike.
I can't get past that my truck does not stall when put in gear.  I tried to force it to stall this morning when I started.  It was less than 20*f when I started this morning.  I gave it less than 3 seconds from running to going into R with the tail of the truck uphill.  No brake, let it just catch 4.
Isn't that the truth. LOL
Nick you are kind of hitting on it but still skirting it. You are missing the roi of the nozzle increase. Takes less time to inject the same amount of fuel. Ecm will over or under shoot as it does not really know you increased the nozzle size. If you still have a stock set of injectors increase the pop.
true,  :think:
wish I could figure out why I am not having stalling issues,  Maybe I am special hahaha.
Edited by Me78569
Smaller injectors with higher pop. Time to find a stock set.
I have all sorts of core sets I can shim up.  How special do you feel nick...  350BAR, 400 BAR, 500BAR?  (I feel like an auctioneer)
Could do more than one set if one wants to install/re install....
@dieselautopower
The thing I want to test most is a set of matching injectors to what I have now, but stock pop pressure.  I want to know what the back to back differences are, if any.
As for why my truck does not stall we would have to do a set of smaller, 75-125 injectors at higher pop and see what happens.  Is my truck "special" or is it somehow a result of being as big as the 7 x .012's are?
I could honestly test injectors until the cows come home.
48 minutes ago, Me78569 said:
true,  :think:
I think with these vp44 trucks, the biggest downfall here is no 2 are the same... I feel like the quality control was subpar. It seems like 5 identical trucks would behave in 5 totally different ways for whatever reason. There all a little "special" if you will.
:iagree:
That we already know, no ifs about it. We're all lucky you're here :hug:
How do you know your current ones aren't tired and already lower on pop pressure then you think. You right you could be testing injectors till cows come home but I think there is a hole in a fence.
Someone want to fix my stalling issue ran ddp 150s 8 holes stalled when cold and my 7x10s stall when cold there is no way I'd be able to to drop my truck in to gear with out letting it idle for at least 10min high idle makes it quicker to be able to take off I have a recon low stall triple disk lmao it did make it a little better when I turned down the line pressure
They have about 2k miles on them now from DAP . they are nearly new, I hope they are still popping at 330 bar
@jlbayes does DDP use sub stock pop pressures ?
On 12/13/2017 at 10:26 AM, Me78569 said:
@kzimmer has a stalling issue if he tries to force it to stall by blipping the throttle etc.    He can make it stall, but his wife has not told him that she has had it stall ( that's key when you consider she drives it mostly and is using the truck as a truck) .    I can make mine stall by blipping the throttle over and over.  I don't know if that is related to pop or injector size.  I never "tried" to make it stall before with the stock pop pressure.    We are missing the "constant" in our testing
It might be %100 related to pop, but we did not test using a stock setup.      Driving my truck I can promise you that you wont make it stall by trying to drive it.
we dont have enough depth in testing to say if increasing pop is "worth it" but there is only one way to know.  Idle Hands, ya know?
What are the real world Perks Vs Drawbacks.
I should note that I had stalling issues with my 60 and 100 hp injectors with my built automatic when it was cold out. @Mopar1973Man can attest to this. However with the proper tuning on the smarty, I managed to have a hand full of stalls this year. But it does seem to stall more likely when shifting from forward to reverse back to forward.
When It's cold out I notice the rate of stalling varies, you can start in reverse and have no issues, or put it into drive and have problems, which makes no sense since reverse line pressure is significantly higher then drive pressure at idle.
On 12/14/2017 at 11:44 AM, dieselautopower said:
I think anything that can be done to improve efficiency, better control over smoke and power is worth looking at. If there are many negatives then its not worth it.  Would like to offer custom pop off pressures on the website so customer can determine the pressures (option box so if they want lowered pressures for P7100 or raised for quadzilla custom tuning) it would be an option for the customer.
The stalling thing is also of interest.  I know people even with rv275 and tight converter that stall constantly in reverse.
For most people it is a moot point as they won'y do anything with it.  Curiosity has a hold on me and I want to support it.
I'm considering pulling you 100's and sending them to you to have them reset to 330 bar.
I dont think it would help honestly.
Try this , enable high idle let it idle up, then drop it into gear without using brake or gas,  does it stall still?
I am sending a set to Nick at 310 BAR.  7x.012VCO @same flow at the nozzles as what he has now.  Nick wants to see  more data on std vs higher pop off pressure.
I will get various datalogs showing as much data as possible along with videos of each setup.
We should be able to compare 0-60 of each setup and see how much difference there is in power.
@Carbur8tr @kzimmer  Any thoughts on what tests I should do to show pros vs cons of the increased pop?
