- Replies 80
- Views 22.7k
TFaoro 27 posts
Mopar1973Man 13 posts
AH64ID 9 posts
trreed 7 posts
UDC vs warp, you can delete emissions with warp, and can not with UDC.
Go tucked... your paint, BJ's, and wheel bearings will also thank you.
Unfortunately I don't think it matters how many smart people get together to try and solve the problem. An EGR is an EGR - they'll always decrease efficiency and fill the intake with soot. The r
Link to the truck info: https://mopar1973man.com/garage/vehicle/143-2014-ram-2500/?show=tab_3
I'm starting this thread to keep track of everything I do to my new to me 2014 Ram 2500 Laramie.
I don't have plans to go crazy with it like I did the 2nd gen. The most it'll probably ever have is a mild towing tune and deletes.
How I bought it: 32K miles Completely stock engine trans. 50 gallon transferflow fuel tank in the bed, Air lift bags with in-cab controls, and a tri-fold tonneau cover.
Picture from the CL ad:
Pictures of the day I got it home:
Big difference between 96 and 2014
I did purchase the factory style in-bed gooseneck kit last week to pull the big trailers with. It's made by Kurt, and everything seems to fit and work as it should. I've put the truck to work right away as my 2nd gen is down at the moment. 2K in the bed there (bags at 20psi)
So from the pictures you can see I don't have the tractor sitting in the right spot. I was being lazy and didn't want to move the tractor after the ramps were up. The first thing I noticed is this truck easily stays level with the bags in the rear. I wouldn't be surprised if the tounge weight was around 3K+ with this load (trailer and tractor together were 13-14K)
It's very different towing with an auto - I've never done it with a larger trailer. The trans seemed fine with the load though. The truck has plenty of power in 1-5 even with 3.42 gears. In 6th at 70mph it is below 1500rpm, so I kept it in 5th.
The turbo spools wicked fast compared to the 2nd gen, although I can clearly feel when torque management is holding the truck back. The exhaust brake feature is awesome. I'm not sure if it works quite as well as an aftermarket one, but it held everything back pretty well.
So far I'm pleased with the purchase! If anyone has questions, ask away!
Edited by TFaoro
