Joining the 300K plus mile club
- Replies 16
- Views 4.7k
Mopar1973Man 5 posts
01cummins4ever 3 posts
CTcummins24V 2 posts
notlimah 2 posts
I wouldn't bother with HY35 turbo too much. Yeah, the J hook can be installed but you have to limit your boost to 30-32 PSI because of the small 9cm2 housing on the exhaust side. Even HX35 would be a
Mine will lock in any gear. Just so ya know. =)
Your transmission isn't normal either...
After 16 years I think it’s time to breath some new life into the old Cummins and get it ready for the next milestone. And do it without spending a fortune
On the real short list , like hopefully in the next few weeks I’ve decided to
1. Install RV 275 injectors ( I know a little late on the originals)
2. Quad XZT or edge Ez, I havnt decided yet, but with my mild tranny I got to take it easy.
3 finish the trans. Lock up switch
Then on the long list which will just keep growing is
1 figure out if I want to spend the big bucks to rebuild 47re or just replace with a manual.
2. Exhaust brake ( I think I would be much happier with a manual )
3. Interior is in dire need of attention, need new dash, seats and replace insulation including under hood.
Any thoughts or do,s or dont’s ?
