- Replies 25
- Views 9.2k
Popular Days
Yes, but I think the OP is also referring to the larger nut still, which should hold the pressure regulation valve in and not be used for pressure adjustments.
The larger nut that holds the regulator assembly to the pump housing can come loose when loosining the jam nut. You may have to hold the larger nut with a back up to prevent this. If it left loose you
Having F/P problems with one of my 2nd gens, AD and me thought there was a regulator problem with the new 150 I got from Vulcan. They sent me another 150 with the agreement that I would send the othe
My fuel pressure kept going up and down. The adjustment "jam" nut (9/16) I can turn but the nut behind it (3/4") also moves. Can't get wrench on it because of bracket is blocking wrenching room. I ground down an old wrench, still not enough room for both wrenches. Problem is created because I turned the airdog 180 so I could use old fass bracket without drilling new/more holes.
Question...if I hang pump on fence and suck fuel out of bucket to set pressure will pressure be the same when hooked up to vp44?
Thought I would bend over vinyl hose to create back pressure.
I don't want to keep taking pump off and on...thought hanging on fence to adjust would be easier. And only have to set one time. Dreaming or good idea?
Thanks
(Edit... pump on fence tottaly independent of vp44)
Edited by 015point9
