- Replies 19
- Views 4.2k
Mopar1973Man 5 posts
015point9 5 posts
JAG1 2 posts
notlimah 2 posts
Should be anything even close to 200* for monitoring at the lift pump. Highest I've seen was 162* and that was from the VP's internal temp sensor.
Be a nice one to have a heat exchanger blow heat off the exhaust over to near the lift pump that you can pull a cable and shut it off for summer. I'm always thinking outside the oil drum.
methanol keeps air lines brake chambers etc from icing over in cold temps believe me from experience it aint no fun to have a trailor or your whole rig freeze up due to ice because your preety well sc
What Fuel temps are you folks seeing?
I want to use 1/4 inch air line left over from putting in air bags. Going to install a test port off a Airdog DF-100. Tubing also known as "Air brake" line. Which is nylon I believe. Best I can see online nylon tubing starts to fall apart around 200 degrees? I have 190 or 195 thermostat. Tubing is stamped SAE j844. Well with in psi but not sure about temps.
Any body know what fuel temps we are dealing with?
