Not starting after warm
First real post here, been lurking in the back ground but now I have a issue you all might be able to help me with. Ok got a 02 gen 2 nv5600, air dog pump. Start it in the morning to warm up (plugged in over night) and blocked wheels cause my driveway is on a incline and my ebreak is not the strongest. Come out to leave and have to put it in gear and shut off truck then remove blocks. Go to start back up and will not start just cranks but does not fire. Now I've been able to get it to start 2 different ways when this happens, either with ether or with my smarty using it to clear the 4 codes it shows. Those codes are as follows.
P0232
P0230
P1475
P1693
Now ive been told i need a new vp, a new pcu or ecu, could be ground issue, could be fuel pump relay issue (already replaced).
Who has had this problem? What was your solution?
THANKS IN ADVANCE!
  • Replies 106
  • Views 19.5k
  • Whats happening then is the AD is running at a full 18 psi (your setting) when the key is ON.  This means the VP is receiving fuel incoming pressure while the engine is cranking, which then increases
  • I should say that I have NOT heard it in a good while. My heating aint what it used to be. You reckon 434k in the 2nd gen might have something to do with it?
  • Fuel pump relay is ONLY for the vp44 in these trucks. It looks like the ecm 5v ref is shorted based on the P1475.
Yes. It will prevent the overcurrent or locked rotor from wiping out the ECM driver for the lift pump circuit.
I've considered whether the lack of fuel pressure to the VP during engine cranking also lessens or removes the electrical load on the PSG during engine cranking.  If the solenoids arent placed under resistance then the electrical load is minimal.  No.....?
There is only two solenoids one for the fuel pin then the other for controlling fuel pressure to the timing piston. Either way the ECM is sending commands for fuel and timing while cranking.
The cranking fuel pressure is only to prevent the timing piston from being over commanded to excessive advancement.
1 hour ago, Marcus2000monster said:
Got it! No way I'm coming iver! Iv got my own beer and I'm having fun! :thumb1:
how the heck do you get a foot long 3/4 inch end wrench on the clear back injector?
If we told where is the fun you speak of?:tongue:
LOL! heck I got it loose before you ever replied! :owned:
It’s probably not possible for a new stock lift pump to create the same over pressure hard starts??
Even though it's very rare for that to be a problem, there's a TSB pertaining to this exact issue.
Ok so yesterday after work went to start the truck and it only cranked never started. Tach was moving all gauges working no issues there. So unplugged the fuse for the AD to see if it would start like it did the day before and nothing. Put fuse back in got pressure back, gave it a little ether and nothing. Had to end up calling AAA and have it towed back to my diesel guy to help me out on figuring this out.
Not sure it would help you or not but I’ve had luck cracking injectors when mine has hot start troubles. Even though I don’t think there’s air in the system
1 minute ago, dripley said:
Is your WTS light coming on?
Yep comes on just like normal.
Just thought I would add to this to say I just tested the lift pump over pressure situation. I have a fairly new stock lift pump btw.
Got truck good and hot then shut it down. Result long cranking, sputtering, no start. I unplugged the lift pump and it immediately flashed right up. I then tried this over several times having no start unless lift pump unplugged.
I have a fass comig and will be wiring up a delay relay when I install it along with a fuel pressure gauge.
I just bump my starter. Watch F/P gauge till it gets up to around 7-9 psi and then crank it. Works everytime
.I don't like the ECM doing the rapid on/off business to the relay. Work truck still needs the protection diode on the relay
Do you need just the relay or the wire harness built for it too?
I just need the relay Daniel. Vulcan supplied the good protection relay on my work truck, but source Automotive did not on the rv camping trip truck. So yes just need the relay and connect it into the harness.
So now you your getting license to drink all my beer at camp :thumb1: Plus some cash there boss:thumbup2:
@JAG1 Sometime in April we'll have to get together and handle the A/C... Unless @IBMobile wants to do it while your camping...
Did you change anything on your truck after starting this thread?
Not a thing.
10 minutes ago, Callsign said:
Not a thing.
Without being there to diagnose in person, I would question whether or not the engine was getting fuel.  Meaning, was the AD even pumping before you realized it wasnt starting.....  Did you confirm the FP gauge was working before the engine didnt start?  Maybe the AD fuse wasnt getting a good connection from you messing with it before.
Then there's the off chance that you could be experiencing more than one issue, like a possible fuel leak which would cause the prime to be lost.
At this stage of understanding whats going on, you need to establish if the VP is getting fuel, then establish if the injectors are getting fuel.  If fuel is being delivered then it "should" start.
Yes in April is good Mike. Promise not to knock on any wood anywhere around there. lol.
