2001 Cummins question?
- Replies 45
- Views 9.8k
Standard Cab01 16 posts
Mopar1973Man 8 posts
Dieselfuture 7 posts
Me78569 4 posts
simply put, the truck ecm calibration is made for stock injectors. This means that at 55 mph you need ~ %30 throttle input, the above map is using that %30 input to see what timing to command.
No I got it from Industrial injection. Part store guy used code reader.
It is my belief that bigger injectors allow you to utlize a different part of the ecm timing maps. Here is the Static State Map, ( not changing rpm, tps, etc) Y axis is rpm, X is how muc
How and why is an rv275 injectors supposed to get better mileage than stock injectors?
