- Replies 71
- Views 16.3k
hex0rz 23 posts
JAG1 9 posts
Mopar1973Man 8 posts
Dieselfuture 7 posts
Mine is still rock solid in both directions. Scares me silly like a hose clamp is going to fly into it from Idaho.
The only thing about Ford's you have to remember is there is a need for a two post lift for lifting the body off. Even like the 7.3L I had a friend call me up to fix oil leaks on his 7.3L the only way
The fix is only in the tail shaft and pretty simple from what I've been told. You have to be careful because a lot of times there is a reason its available. That's why I like a tight truck
With the growth projections in my apiary operation, the need to transport my hives efficiently are becoming greater. With this in mind, the need for a dually takes precedence. I have considered a gooseneck trailer and its still not off the table.
The popular method for beekeepers of commercial sizes use flatbed dually trucks and then pull their loader on a trailer.
The only consideration i would make for a dually is a 12v or 24v. But i need the towing capacities and hauling. Usually 96 hives fit in a flatbed over the axle and then trailer/loader. I'm looking for a 5 or 6 speed transmission and ex cab, 4x4.
Hard find at a decent price!
